Maverick Landing Gear
Leon Joubert
Post by Leon Joubert » Mon Jan 26, 2015 5:09 am
Hello Murphy Builders,
I am a new member from South Africa building a partially completed Maverick (S/N 0136). The previous owner had done some good work on the tail feathers and wings and I have almost completed the fuselage.
The kit was shipped (back in 2008) with the spring gear option which was never received. (neither was the tail wheel leaf spring). I would have preferred the standard bungee gear but am now committed to using a spring gear due to mods already done.
I have access to an engineering works who can bend me a proper aluminum spring gear (2024 I think) but I need some dimensions in order to have it made.
What I need is as follows:
1) Plumb distance from firewall bottom to wheel axle center (i.e. gear-leg-hight)
2) Distance from wheel to wheel (i.e. gear-leg-width or wheel base)
Could someone please point me in the right direction as to where I might find these dimensions.
Leon Joubert
Monocoupe
Re: Maverick Landing Gear
Post by Monocoupe » Mon Jan 26, 2015 9:28 am
Hello Leon,
A word of cation here. The Maverick spring gear is not at all like the Rebel spring gear. The Maverick gear is a tapered steel rod type that mounts to the vertical members of the main cabin bulkhead. The floor structure of the Maverick is not suitable for a bottom mounted aluminum gear. I would seriously look at re-configuring back to the bungee gear if it were my project.
You can contact me directly at the factory if you like. murtech@murphyair.com or (604) 792-5855 ext 236
Cheers, Nigel
Leon Joubert
Post by Leon Joubert » Mon Jan 26, 2015 10:21 am
Hi Nigel,
Thanks for the reply. Much appreciated.
Yes I would prefer the standard gear but the previous builder had already cut off all the mountings for this.
I realize the cabin floor can not accept a spring gear by itself as is, therefore I am devising a plan to transfer the loads to the original mounting points (or as near as possible).
May I run this past you when I have some drawings please?
Could you please give me the dimensions needed for the landing gear?
1) Gear height (firewall bottom to wheel center)
2) Gear width (wheel to wheel inboard)
I sent you email to murtech@murhyair.com but it could not be delivered - any idea why?
Leon.
mikefairbanks
Site Admin
Post by mikefairbanks » Mon Jan 26, 2015 10:30 am
Leon,
Check your spelling... you have the email listed as murtech@murhyair.com... should be murtech@murphyair.com... notice the missing "p".
Mike Davis
Fairbanks, Alaska
"I'd rather be flying!"
Leon Joubert
Post by Leon Joubert » Mon Jan 26, 2015 10:48 am
Mike,
Thanks for the correction but ironically I made the error only in the Post. The actual address I mailed to was correct. I tried it a few times - bounces every time. Seems the error lies with my SP.
Leon.
Monocoupe
Post by Monocoupe » Mon Jan 26, 2015 11:12 am
Hi Leon,
The murtech address was supposed to have been fixed....apparently not. :roll:
Try shipping@murphyair.com Lets talk about your landing gear as I think I can help you out here.......
Cheers, Nigel
Monocoupe
Post by Monocoupe » Mon Jan 26, 2015 2:46 pm
Leon,
I recieved your test e-mail at shipping and have replied. I'm thinking that you may not have recieved it as apparently nobody else has recieved any of my e-mails today from either address. We have been experiencing problems with our system.......they are working on it!
Cheers, Nigel
Monocoupe
Post by Monocoupe » Tue Jan 27, 2015 4:48 pm
Hi Leon,
I have been recieving your e-mails but it would appear that nobody is getting my replies. System problems continue I'm afraid. I will respond as soon as our problems are fixed. As for the picture that you sent me of Maverick S/N 003, those gear legs are the tapered steel rod type, but with sheet aluminum fairings over them.
Cheers, Nigel
