rivet size question
Pthompsn
rivet size question
Post by Pthompsn » Mon Dec 29, 2014 4:03 pm
I'm building Rebel 320R and have a manual dating to 1993. on page 302 it gives instructions for riveting the roof onto the frame. On step 276 subparagraphs 3) it reads - 1/4" x 3/16" avex rivet in top carrythrough gussets.
I can't find an avex rivet in this size (1/4 x 3/16") at any supplier.
Any info on this rivet would be appreciated
Dale
Re: rivet size question
Post by Dale » Mon Dec 29, 2014 4:21 pm
Rivets are described by diameter and grip length.
Therefore the Rivet will be 3/16" diameter..... 1/4" (.250") will indicate grip length.
Here's a link for a 3/16th .250" avex rivet....
https://www.fastenal.com/web/products/details/11544444
Dale
British Columbia, BC
Mountain Flying at Its Best
Post by Jerry Folkerts » Mon Dec 29, 2014 5:13 pm
You can also get smaller quantities from Aircraft Spruce and Specialty.
Dale
Post by Dale » Mon Dec 29, 2014 5:19 pm
Jerry,
The link was just for Rivet Information reference.
You can buy is smaller quantities from this company also. I referenced this company because it is local to me.... No shipping costs.
Dale
Post by irishfield » Mon Dec 29, 2014 5:57 pm
It's a typo.... as there are NO 1/4" rivets in a Rebel.. unless you screwed up and make that happen... :shh:
It should read 3/16 x 1/4" rivet.... or to be real easy it should read RV1613 ! :thumbup:
Pthompsn
Post by Pthompsn » Mon Dec 29, 2014 6:04 pm
Thanks for the reply. I thought the first number 1/4" was the diameter number and the 3/16" the grip.
If the numbers were 3/16 x 1/4 it would make sense.
That is why I am suspect of a typo
Again,thanks thanks for the reply
Pthompsn
Post by Pthompsn » Mon Dec 29, 2014 6:31 pm
Thanks. Very helpful info.
RV 1613 (3/16 x 1/4)
RV 1619 (3/16 x 3/8)
Post by irishfield » Mon Dec 29, 2014 7:04 pm
Yes... you are correct...1613's up there. .not 1619's! I'm allowed one slip up a week, based on my salary! Was thinking "gusset plates" needed the longer one, but the top plates are thinner than the lower ones where 1619's are used.
Rebel778
Post by Rebel778 » Fri Feb 13, 2015 5:32 am
Is there anywhere other then Mam to get the Rv1613 and Rv1619 rivets ?
Post by Jerry Folkerts » Fri Feb 13, 2015 6:57 am
There are quite a few rivet suppliers. Aircraft Spruce and Specialty has them. In the US, Hanson Rivet is a good source, but minimum orders apply.
Elite773
Post by Elite773 » Fri Feb 13, 2015 10:21 am
Mattic Industries Ltd
17670 65A Avenue #101
Surrey, BC V3S 5N4
