I have recently completed the installation of a heated pitot tube in my left
wing. I ran aluminum tubing through the leading edge ribs to a bulkhead
fitting at the wing root. My plan was to then switch to nyloseal tubing the
rest of the way. Why not nyloseal all the way? Hell, I don't know! Seemed
like a good idea at the time. Then I discovered that there are no threaded
nyloseal fittings that are compatible with metal AN fittings. So I have to
use an AN bulkhead fitting that adapts to a regular push on tube fitting.
Rats. I wanted threaded fittings all the way. Maybe I'll just yank the
aluminum tubing and AN fittings out and go nyloseal all the way. What have
you other builders done?
Pitot installation
Drew and Jan
Pitot installation
Mike I just used push on fittings on mine with no problems put a double
wrap of safety wire on each joint and it won't leak. On the pitot line
where it enters the fuselage use a tee instead of an elbow and add a
lenghth of hose pointing down with a cap on the end for any water that gets
into the system to collect in. I didn't do this and had my airspeed freeze
while flying one day.
----*You have received this message because you have subscribed to the
murphy-rebel mailing list.
Rick and Cathy Ford
Pitot installation
I have a heated pitot tube in my right wing.
I ran 2 aluminum tubes (pitot & static) from the pitot tube through grommets
that stick out of the lower leading edge at the wing attach point.
This way I have nothing but aluminum sealed away in the wing. I never trust
nylon tubing to last forever and expect to replace it years down the road.
Then I ran nylon tubing down the wing strut and through grommets in the side
of the fuselage.
There they connect into 90o compression fittings that then go up to the ASI.
I'll post 3 pictures on dcsol showing these points.
Rick Ford
Sent: Friday, March 02, 2001 9:02 PM
Subject: Pitot installation
of the fuselage.
Rick Ford
leftI have recently completed the installation of a heated pitot tube in my
thewing. I ran aluminum tubing through the leading edge ribs to a bulkhead
Seemedrest of the way. Why not nyloseal all the way? Hell, I don't know!
threadedlike a good idea at the time. Then I discovered that there are no
tonyloseal fittings that are compatible with metal AN fittings. So I have
haveuse an AN bulkhead fitting that adapts to a regular push on tube fitting.
*---------------------------------------------------------------------------you other builders done?
*---------------------------------------------------------------------------You have received this message because you have subscribed to the
AGT
Pitot installation
Did you go out the lower leading edge because you didn't want to weaken the
root rib with holes? I went out the root rib. I also wanted aluminum in
the wing for the same reason as you. I'm going to leave the aluminum tubing
in the wing, and use a bulkhead fitting at the root rib that adapts to a
push on tube fitting to convert to nylon tubing there. Haven't figured out
where I go from there yet. Just got the fuselage tailcone done. I've got a
ways to go.
Rick and Cathy Ford
Sent: Sunday, March 04, 2001 5:07 AM
Subject: Re: Pitot installation
of the fuselage.
Rick Ford
ways to go.
Rick and Cathy Ford
of the fuselage.
Rick Ford
Rick and Cathy Ford
Pitot installation
I went this way because I have a switch panel above the windshield, thus
there are a lot of wires routed down each side of the windshield.
I didn't want to try adding a couple nylon tubes in there also.
Your installation may be different and will allow you to route the tubes
there.
I found that area a little difficult to work with because there are no
obvious provisions for tubing and wiring.
Rick.
Sent: Sunday, March 04, 2001 1:37 PM
Subject: RE: Pitot installation
there.
Rick.
theDid you go out the lower leading edge because you didn't want to weaken
tubingroot rib with holes? I went out the root rib. I also wanted aluminum in
outin the wing, and use a bulkhead fitting at the root rib that adapts to a
awhere I go from there yet. Just got the fuselage tailcone done. I've got
*-------------------------------------------------------------------------*ways to go.
Rick and Cathy Ford
grommetsMike
trustthat stick out of the lower leading edge at the wing attach point.
sidenylon tubing to last forever and expect to replace it years down the road.
ASI.of the fuselage.
*-------------------------------------------------------------------------*I'll post 3 pictures on dcsol showing these points.
Rick Ford
fitting.leftI have recently completed the installation of a heated pitot tube in mythewing. I ran aluminum tubing through the leading edge ribs to a bulkhead
fitting at the wing root. My plan was to then switch to nyloseal tubingSeemedrest of the way. Why not nyloseal all the way? Hell, I don't know!threadedlike a good idea at the time. Then I discovered that there are notonyloseal fittings that are compatible with metal AN fittings. So I haveuse an AN bulkhead fitting that adapts to a regular push on tube
*---------------------------------------------------------------------------haveRats. I wanted threaded fittings all the way. Maybe I'll just yank the
aluminum tubing and AN fittings out and go nyloseal all the way. Whatyou other builders done?
list-server@dcsol.com---*You have received this message because you have subscribed to the
*---------------------------------------------------------------------------with "unsubscribe murphy-rebel" in the body of the message.
