[rebel-builders] Part Fus 69 Rear Wing Attach bracket
Post by Wayne G. O'Shea » Mon Feb 20, 2012 2:34 am
Doug, some of the older kits use to be supplied with 12 x W124's.. and you
used four of them for the wings and eight for the cabin rear attach. Issue
with this was the outer three bolts in the fitting ended up real tight to
the end of the cabin bulkhead making it a tad harder to work on. Because of
that the Fus-69 was brought into play to move the bolts back (inboard) about
5/16 of an inch or so (that difference in length you see between the two
fittings). So that said... you could use all W124's if you can't find 6 more
Fus-69's.
I just went and checked...and from all the wing rebuilds I've done over the
years I have a stack of eighteen new W-124's. So if you can't get 6 x
Fus-69's from a list member, or factory, let me know and I'll send you 3 of
my W-124's so you have a dozen of them to carry on.
To: "rebel builders" <rebel-builders@dcsol.com>
Sent: Wednesday, November 16, 2011 9:34 AM
Subject: [rebel-builders] Part Fus 69 Rear Wing Attach bracket
I can only find 2 of these parts (Fus 69) I think I need 8 of theses (of
which 4 of them I will have to trim to except w124 attached to the rear
wing spar.) I have 9 of w124 and only need 4 These parts are similar but
the Fus 69 are a bit longer Does anyone have any extra Fus 69 parts ?
ThanksDoug Farrow778Rebel
Doug Farrow
Post by Doug Farrow » Mon Feb 20, 2012 2:34 am
Thanks Wayne
Sent from my iPhone
Fus-69's.
