they should have had a better transmitter, remote antenna and closer
spaced reports. Also, they can't be used in the far north because of
satellite reception and they are miserable to deal with. For what they
provide they are very expensive in my opinion. I have one probably for
the same reason as you but after 2nd year won't renew the contract.
We are now using a cheap Ameri-King 451 upgraded to accept GPS. The
procedure is going to be in the event of a serious problem we will
activate the ELT and answer questions later. It really amazes me that TC
can't figure out that 406 is never going to work in a crash, maybe on
the prairies if it stops right side up.
Bob
On 11/3/2011 6:32 AM, jessejenks72@gmail.com wrote:
I love my AK 121.5 elt. It looks just as orange and useless as the day I got it, and it was cheap.
When 406 becomes mandatory I will probably get the cheapest one of those too.
I got a Spot because I actually want to get rescued.
Sent from my Verizon Wireless 4GLTE smartphone
----- Reply message -----
To:<rebel-builders@dcsol.com>
Subject: [rebel-builders] 406 ELT recommendation
Date: Wed, Nov 2, 2011 3:34 pm
Talk with Carl and tell him you were talking with me about going 406. We go
back to the day he opened shop and he's a straight shooter. If he says the
retro kit is okay, then he means it. If he says to sell it on ebay and buy a
Kannad well like I said he's as honest as they come.
Sent: Wednesday, November 02, 2011 5:26 PM
Subject: RE: [rebel-builders] 406 ELT recommendation
Looks like I misspoke. After checking the box again it appears I have a
ACK-e01. Not sure if they use the same type of housing as Ameri-King, but
they look similar. Discount Avionics has a retrofit kit for $580.00. Does
this change the story at all, or is it still not worth putting the money
into this. I have no experience with the various brands. As I don't have
anything installed in the plane yet, I can purchase whichever.
Roland
G. O'Shea
Sent: Wednesday, November 02, 2011 4:18 PM
Subject: Re: [rebel-builders] 406 ELT recommendation
I still don't think anything has been finally finallized on the 406 fiasco
here in Canada Roland....so you'd be legal to start off with the AK-450
way it is (if it tests okay that is) and change over later.
I absolutely would not spend the $$$'s to update an AK to a 406. Their
biggest enemy is corrosion for terrible sealing. Carl Bertrand (owner
Discount Electronics) absolutely swayed me away from any AK products to go
406 on Bob White's Elite. We did his aircraft this spring (after TWO
AK-450's hit the garbage can for it in 3 years). The unit that was
recommended at the top of his list, for the best moisture seal, was the
KANNAD AF Compact
http://www.discountavionics.com/elt%204 ... compact.ht
m
It's gonna set you back a thousand bucks... or I see they now have one
with
built in GPS for $200 more.
The KANNAD AF Compact was easy to install. The tray has multiple holes to
match just about any existing ELT tray bolt holes and I bolted it right
into
the orginal spot. A new switch has to be wired into the panel location, as
you can't use the old one, but if I remember correctly it only required 3
wires so I used the existing "phone" cable that was already pulled through
the airframe and connected it to the new plugs for unit and switch.
Sent: Wednesday, November 02, 2011 2:10 PM
Subject: RE: [rebel-builders] Encoder Recommendation ?
Wayne, I received an older AK ($500 to upgrade) with my kit. I will
either
have to upgrade it to 406 or purchase new. What brand or type would you
recommend other than AK?
Roland
G. O'Shea
Sent: Wednesday, November 02, 2011 10:11 AM
Subject: Re: [rebel-builders] Encoder Recommendation ?
I agree with you on their ELT's Bob. Absolute JUNK! I have 6 of those
"duracell" battery style ELT's in the filing cabinet all with osillator
failure or worse. One was it's first time in for recert! If anyone here
is
running one of those orange AK-450's... even though the red light comes
on
during test it DOES NOT mean it actually can transmit a signal.
Sent: Wednesday, November 02, 2011 2:09 AM
