[rebel-builders] Fwd: restored and modified Rebel
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:42 pm
Looks neat Karl... just please tell me that the boarding step is bolted to a
tube clamp that goes around that rear drag strut and that those two bolts
aren't thru a hole drilled in the strut.
Sent: Wednesday, February 23, 2011 10:25 AM
Subject: [rebel-builders] Fwd: restored and modified Rebel
fellow rebel builders
Here is a link to some pics of my Rebel. It was built in 1996 but had
not flown since 2003. I bought it last spring and brought it home on a
trailer.
It has a 160 HP Subaru engine and Warp Drive prop.
The original wheel on the left "broke" while I was taxiing on rough
ground and it jammed and the plane flipped on it's back.--before I even
flew it-- Bob Patterson told me then that the running gear I had was
"recalled"
--apparently go kart stuff--really way too lightweight--
I used front running gear from a Kawasaki Brute Force 4 wheeler. Some
machining to make bearing housings
and modification of the axle housing and some welding. The rims are
aluminum 4 wheeler rims
Farm implement tires that cost about $60 each. I had the tread
machined off by a local re-capping company. This is way cheaper than
Alaska Bush tires and you have a heavier
duty system including the brakes.
A few panels got wrinkled in the flipover so I incorporated some mods
while replacing them. I added
VG's. The aluminum tailspring had been bent straight by the previous owner
due to a hard tail landing. When I put it in a press to rebend it I found
it had no "spring"
so I made a spring from some trailer springs. It now has good bounce to
fix landing "mistakes"
I also could not stand the door setup--it seemed I was always "fighting"
the door while getting in the airplane. I like the flip up conversion much
better. Thats the way the kits should be
produced in my opinion.
I like to fly with doors open as I used to do in Kitfox I once had but
there is too much
buffeting with the Rebel. I installed a solid bulkhead per Bob Pattersons
suggestion and it did help some
http://www.flickr.com/photos/59852993@N02/
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 11:42 pm
Hello Wayne
My comment is in reference to your reply to Karl's boarding strut. I realize
no holes should be drilled thru the aluminum drag strut but I was surprised
to hear the strut could even take the side loads if used for boarding. I
have your die spring gear and I am 5' - 7" and a senior citizen (for a long,
long time) and I have difficulties climbing in and out. My wife (copilot)
who is only 5' - 1" and 105 Lbs. keeps asking me how she is going to get in
and out of the Rebel. So far I have just ignored the question but is this
even an option? Up to now I though I would just fabricate a portable light
weight step and keep it in the plane. Would appreciate any thoughts and
suggestions?
Charlie E. 802R
Sent: Wednesday, March 02, 2011 8:24 PM
Subject: Re: [rebel-builders] Fwd: restored and modified Rebel
trailer.
"recalled"
owner
it had no "spring"
much
there is too much
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
Charlie.. it might take your wife's weight hopping in there from time to
time..... but anything more than that I personally think you'd be asking for
trouble over time. One day your gonna give your 265lb buddy a ride.. he's
gonna grab that light door and damage it, at the exact same time he jumps on
the "wife only" step before you can yell NOOOOO !
Sent: Thursday, March 03, 2011 10:40 AM
Hello Wayne
realize
surprised
long,
in
suggestions?
Charlie E. 802R
trailer.
"recalled"
owner
found
it had no "spring"
much
there is too much
Pattersons
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
karl hipp
Post by karl hipp » Sun Feb 19, 2012 11:42 pm
The brace strut seems to be a pretty stout piece of alloy aluminum. I
had it off to repair the weak point which is the mounting area for the
tabs the back of the strut attaches to. I replaced the 1 x 1 internal
square tube that is sandwiched between the tabs with a heavier and
longer piece so I could bolt it to the 2 x 2 channel that extends to and
bolts into the forward crosspiece. I disagree that bolt holes thru the
strut might weaken it. By bolting (actually large rivets) the step to
the main strut, and bolting it to the drag strut,I believe it actually
makes the assembly stronger. I weigh 220 pounds. I can jump on the step
with no deflection of any components.
Karl
To:<rebel-builders@dcsol.com>
trailer.
"recalled"
it had no "spring"
there is too much
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
Not gonna argue with your Karl.. just offering advise based on the pile of
mangled gear leg assembies (that I never seem to throw out) in the far
corner of the shop. A 16 year collection of others misfortunes.
You say you can jump on that step without any deflection of any compenets,
like the drag strut or wear and tear on that 1/4" bolt hole and bracket
that's holding same to the back side of the axle gusset... I'm sorry but I'm
gonna say bullshit!
Sent: Thursday, March 03, 2011 1:17 PM
Karl
to a
trailer.
"recalled"
owner
found
it had no "spring"
much
there is too much
Pattersons
Karl Hipp
Crawford Airpark
Crawford Co
970 963 3755
karl hipp
I didn't say there might not be some wear and tear Wayne, but with the
bigger wheels and the stock door I was having an impossible time getting
in and out.
Now with the flip up door and step it is not a problem. If wear develops
somewhere I am happy to deal with it.
I do not think that what we have in a Murphy Rebel is a 10,000 or 20,000
hour airframe as in a Cessna 172 or a Piper Comanche. These little
buggers require constant attention as they were never "designed" (if I
can use that word loosely) for endurance operations.
For the trade off of an inexpensive -work on it yourself no STC's needed
airplane, I am happy to make mods and do repairs as needed.
As far as normal operations--like hard landings, I thing the step and
the mod I did to the rear attach point along with the angle under the
door make the gear brace more tougher!!
Karl Hipp
gonna say bullshit!
Karl
to a
Post by Drew Dalgleish » Sun Feb 19, 2012 11:42 pm
Mike Ash has a plastic stepstool that he carries in his rebel for his
vertically challenged wife. It's very gentlemanly the way he helps her
in before walking around and storing the step and getting in himself.
On 03/03/2011 10:40 AM, Charlie Eubanks wrote:
Hello Wayne
suggestions?
Charlie E. 802R
karl hipp
we use a plastic stepstool to get in the cargo door of the Confederate
Air Force TBM Torpedo Bomber flown by the Rocky Mtn Wing.
A short rope attached to the stool retrieves it into the cabin. With a
little practice you can throw it out and work the rope to get it land
upright.
Karl Hipp
Hello Wayne
suggestions?
Charlie E. 802R
Bill Maxwell
Post by Bill Maxwell » Sun Feb 19, 2012 11:42 pm
Hmm, I replied to this post but it appears to have vanished when my ISP
went off air.
I adopted a similar approach early last year, while I was suffering
plantar fasciitis in my right heel. That made it very painful when
trying to step up onto the wingroot of my Jodel D18. The height above
ground was not great but too far for the pain barrier.
A trip to Bunnings, our version of Lowes or Home Depot, revealed a cheap
Chinese plastic single-step folding stool at $17.99, rated at 100kgs.
This proved just the right height on first tests, so I drilled two
diagonally opposed holes in the corners, near the outer edge but missing
the reinforcing ribs. I then passed the ends of a length of blind cord
through each hole and tied large knots on the end of the cord, under the
stool. This both prevents the cord from pulling back through the holes
and also means the stool can be lifted by the cord while remaining unfolded.
Once aboard, it is a simple task to retrieve the stool via the cord,
fold and stow it away. On arrival, the process is reversed, with the
stool unfolded and lowered to the ground ready for use. It worked so
well that although I no longer need it, at least unless the plantar
fasciitis returns, I now keep it in the plane to assist other less
mobile crew members. It is also very handy when filling the main tank
ahead of the instrument panel and also when working on the engine once
the cowls are removed, both as a step-up and as a seat.
Bill,
either 735R or 753R, I currently forget which.
Hello Wayne
suggestions?
Charlie E. 802R
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1204 / Virus Database: 1435/3478 - Release Date: 03/02/11
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 11:42 pm
Bill, can you point me to one of these plastic wonders of which you so
glowingly speak? Googling "plastic folding stool" and similar constructions
yields a number of things, but I don't want just any old "plastic [Chinese]
folding stool". I want the one that's already been tried and pilot-tested!
went off air.
unfolded.
Bill,
Bill Maxwell
Hi Ron
It no longer appears on Bunning's webpage catalog, unfortunately,
although it has been available here for some years. We bought our first
example in about 2007 for use in our motor home, something I had
forgotten until I found them again in the store.
eBay item 360320377160 looks similar, although it suggests a higher
loading maximum than mine. eBay item 300532243044 might be even a more
rugged version, if the maximum loading is any guide.
The construction of mine features a lattice rib structure, in diamond
formation, on the underneath surface of each panel, with a flat exterior
surfaces, if that helps.
Bill
went off air.
unfolded.
Bill,
Version: 10.0.1204 / Virus Database: 1435/3479 - Release Date: 03/03/11
wayne.pederson
Post by wayne.pederson » Sun Feb 19, 2012 11:42 pm
Try this on mmmmmmm
made in the USA
http://towerstool.com/plasticstools.html
On 3/3/2011 7:30 PM, wrmaxwell@bigpond.com wrote to rebel-builders:
-> Hi Ron
-> It no longer appears on Bunning's webpage catalog, unfortunately,
-> although it has been available here for some years. We bought our first
-> example in about 2007 for use in our motor home, something I had
-> forgotten until I found them again in the store.
-> eBay item 360320377160 looks similar, although it suggests a higher
-> loading maximum than mine. eBay item 300532243044 might be even a
more
-> rugged version, if the maximum loading is any guide.
-> The construction of mine features a lattice rib structure, in diamond
-> formation, on the underneath surface of each panel, with a flat exterior
-> surfaces, if that helps.
-> Bill
-> On 4/03/2011 2:34 PM, Ron Shannon wrote:
-> > Bill, can you point me to one of these plastic wonders of which you so
-> > glowingly speak? Googling "plastic folding stool" and similar constructions
-> > yields a number of things, but I don't want just any old "plastic [Chinese]
-> > folding stool". I want the one that's already been tried and pilot-tested!
-> > Ron
-> > On Thu, Mar 3, 2011 at 5:12 PM, Bill Maxwell<wrmaxwell@bigpond.com>
wrote:
-> >> Hmm, I replied to this post but it appears to have vanished when my
ISP
-> >> went off air.
-> >> I adopted a similar approach early last year, while I was suffering
-> >> plantar fasciitis in my right heel. That made it very painful when
-> >> trying to step up onto the wingroot of my Jodel D18. The height above
-> >> ground was not great but too far for the pain barrier.
-> >> A trip to Bunnings, our version of Lowes or Home Depot, revealed a
cheap
-> >> Chinese plastic single-step folding stool at $17.99, rated at 100kgs.
-> >> This proved just the right height on first tests, so I drilled two
-> >> diagonally opposed holes in the corners, near the outer edge but
missing
-> >> the reinforcing ribs. I then passed the ends of a length of blind cord
-> >> through each hole and tied large knots on the end of the cord, under
-> >> stool. This both prevents the cord from pulling back through the holes
-> >> and also means the stool can be lifted by the cord while remaining
-> >> unfolded.
-> >> Once aboard, it is a simple task to retrieve the stool via the cord,
-> >> fold and stow it away. On arrival, the process is reversed, with the
-> >> stool unfolded and lowered to the ground ready for use. It worked so
-> >> well that although I no longer need it, at least unless the plantar
-> >> fasciitis returns, I now keep it in the plane to assist other less
-> >> mobile crew members. It is also very handy when filling the main tank
-> >> ahead of the instrument panel and also when working on the engine
once
-> >> the cowls are removed, both as a step-up and as a seat.
-> >> Bill,
-> >> either 735R or 753R, I currently forget which.
-> > No virus found in this message.
-> > Checked by AVG - www.avg.com
-> > Version: 10.0.1204 / Virus Database: 1435/3479 - Release Date:
03/03/11
wayne.pederson
My wife got one of these at WalMart
Rated at 300 pounds and the inside is like honey combed
-> Hi Ron
more
-> Bill
-> > Ron
ISP
-> >> went off air.
cheap
missing
-> >> unfolded.
once
-> >> Bill,
03/03/11
Ron Shannon
Ah yes, found the B&R Plastics EZ-Foldz 101-6x (USA) on Amazon:
http://www.amazon.com/gp/product/B000GARM5K
Thanks Bill & Wayne.
Bill Maxwell
Looks much like mine, Wayne and thanks, honeycombed is the description I
was searching for.
Bill
-> Hi Ron
more
-> Bill
-> > Ron
ISP
-> >> went off air.
cheap
missing
-> >> unfolded.
once
-> >> Bill,
03/03/11
