[rebel-builders] Torque wrench
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 9:31 pm
There are a lot of sources. Automotive, Aviation, Snap-on, Proto, Mac,
Craftsman, etc. What do you want to torque?
I have a Snap-on 0" to 200"/lb clicker type with the quarter inch drive that
I use for most of my work (A/P, IA, Titan Rocket engine builder) prior to
retirement.
I also have a Proto 100" - 1500"/lb 3/8" drive clicker that I use for the
higher values. These meet most of my needs.
I also have some much bigger and much smaller ones for specialty
requirements. On a Slick magneto the "P" lead is about 20"/lb you will
brake the ceramic insulator of the capacitor if you do it by hand to what
you feel is tight. On some Rocket engine components I have applied 600
foot/lb to the mounts.
Another type of Tq Wrench is the bending arm with a pointer, or a Dial. Now
days I believe they make digital versions.
When a torque of drag plus specific torque is called out, I always used a
dial to get the drag of each nut, then add that amount and continue to the
called out value + drag.
Calibration: At the Rocket factory we had purchased about 25 new wrenches
at one time, we sent them to our cal. Lab., 5 of them were rejected as
outside of our 5% requirement. Another tid-bit, we did not use a tq wr in
the bottom 20% of it's range, so if it was a 200"/lb we did not use it at
less than 40"/lb. I believe that is a good policy myself, because most were
not accurate in that range when we did our required daily tests. Yes this
may have been over kill but in several hundred pay-load launches our engines
never caused a failure to place a satellite in proper orbit.
SO be aware, not all torque wrenches are calibrated equal. Another thing if
one is dropped!!! God forbid the Dog knocked it on the hard cement
floor...It SHOULDE BE re-checked.
The FAA wants to have you have them calibrated each 2 years. Of course we
are building Experimental Airplanes so if a wrench is out of calibration it
shouldn't matter...right.
At a big shop that, I once operated the single engine department, WELL the
multi eng guys installed a prop on a 421C and pulled 2 of the studs out of a
prop before the mechanic questioned if it was a bad prop, or his torque
wrench. Needless to say ALL torque wrenches, company and personal, went out
for calibration. About 20% needed repair or retirement. We also added a
torque meter for daily checks.
Dick Wampach SR-108 N331RW
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Kelly
M. Ewing
Sent: Thursday, August 05, 2010 11:49 AM
Subject: [rebel-builders] Torque wrench
Good afternoon all, anyone know where to get a decent torque wrench? I know
spruce has them, just want another source.
Kelly ( Moose )
Canada
kelly@tru-form.ca
Post by Ken » Sun Feb 19, 2012 9:31 pm
Princess auto carries 1/4", 3/8", and 1/2" drive torque wrenches. The
1/4" one is fine for everything on the airframe except the engine. They
do mail order and have a website if you aren't close to a store.
Occasionally they go on sale. Probably not the most accurate things but
mine was fine when I checked the calibration.
Kelly M. Ewing wrote:
Good afternoon all, anyone know where to get a decent torque wrench? I know spruce has them, just want another source.
Kelly ( Moose )
Canada
kelly@tru-form.ca
Enjoy your day !
Andrew Burr
Post by Andrew Burr » Sun Feb 19, 2012 9:31 pm
I have a Snapon that I have been using for 25 years now. Not the cheapest but it is the best.
Andrew E Burr XIV
Vertical performance LLc
Po Box 213
Cassville MO 65625
VPHelo, LLc has paid for the design and engineering for every component and holds ownership of all intellectual property for each component.
--- On Fri, 8/6/10, Ken <klehman@albedo.net> wrote:
Subject: Re: [rebel-builders] Torque wrench
Date: Friday, August 6, 2010, 12:15 AM
[quote]Good afternoon all, anyone know where to get a decent torque wrench? I know spruce has them, just want another source.
Kelly ( Moose )
Canada
kelly@tru-form.ca
Enjoy your day !
J Portman
Post by J Portman » Sun Feb 19, 2012 9:31 pm
I am a real Craftsman fan. Free replacement for life. I've got several
different TW's around the hangar, but the important jobs get the Craftsman.
Had it checked once after I got it, then once every couple years.
JP
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
The 1/4" one is fine for everything on the airframe except the
engine. They do mail order and have a website if you aren't close to
a store. Occasionally they go on sale. Probably not the most
accurate things but mine was fine when I checked the calibration. Ken
Kelly ( Moose )
Canada
kelly@tru-form.ca
Enjoy your day !
Miller, Ross W
Post by Miller, Ross W » Sun Feb 19, 2012 9:31 pm
Same here on the Craftsman.
RM
203SR
To: rebel-builders@dcsol.com <rebel-builders@dcsol.com>
Sent: Thu Aug 05 23:42:46 2010
JP
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
Kelly ( Moose )
Canada
kelly@tru-form.ca
Enjoy your day !
