[rebel-builders] RE: Rear drag brace failed
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 9:31 pm
Well, sounds like you need the builder's manual....... maybe you should get
that from the guy you bought the a/c from. Good luck with your repair.
O and remember, while not everyone will have the "answer" you're looking
for....... they're still here to offer they're assistance the best they can
and that's something to respect.
Jeff
On Sat, Jul 24, 2010 at 11:02 PM, <caltrac@dcsol.com> wrote:
7-24-10, Bransom your answer was not very helpful. Well, what failed?
Sheered rivets maybe even bolts that hold the drag brace on. I don't have a
clue untill I open up that area. To bad the builder and the plans didn't
think
to put an inspection opening is this vital area. This should be a heads-up
new builders that an inspection opening might be a nice thing to consider,
so
that when that hard landing comes or that rough field landing you weren't
expecting just rattled your teeth. you have a way to make sure your gear is
still in good shape before you go airborn again..
I need guidance starting with how to jack up the airplane. As I wrote
there is no outward damage but something is making a lot of "dragging a tin
can" noise, pretty loud too when I taxi. A visable movement of the tire
forward and reverse also as I wrote. Of course I've searched the
entire "list"! Not much help to me to read "how easy it was to repair",
when
what I need is a step by step or even a scanned copy of the drawing of the
landing gear drab bracket area, so I can see what is on the inside. Tks
all
caltrac@frontier.com
Jeff Micheal
Caltrac........
I think you're in the wrong forum..... Cause nobody here is looking to have
your ^%$* thrown at them, back off and move on to the I want to start a
fight forum.
Try siging off your post with a name....... or don't you want people to know
who you are.
Jeff
On Sun, Jul 25, 2010 at 10:13 AM, <caltrac@dcsol.com> wrote:
What are you telling me that for? Maybe you don't understand, that I
didn't
order anyone to cut a hole in the structure. I said to consider an
inspection
port to observe the gear attach points, useful to check how they are
holding
up after a hard or soft landing. Are you sure you are a homebuilder?
Maybe
you don't understand what the homebuilder movement is all about. Stop
trying lead my inquire. On 7/25/2010 6:55 AM, kpierson wrote to caltrac:
-> Most builders on this site are not engineers and are reluctant to
-> cut holes in a structure, however, if a hole is cut it should be well
-> reinforced.
-> Keith P. 318R
-> On 7/24/2010 10:02 PM, caltrac wrote to bransom:
-> -> 7-24-10, Bransom your answer was not very helpful. Well, what
failed?
-> -> Sheered rivets maybe even bolts that hold the drag brace on. I don't
have
-> a
-> -> clue untill I open up that area. To bad the builder and the plans
didn't
-> think
-> -> to put an inspection opening is this vital area. This should be a
heads-
up
-> to
-> -> new builders that an inspection opening might be a nice thing to
consider,
-> so
-> -> that when that hard landing comes or that rough field landing you
weren't
-> -> expecting just rattled your teeth. you have a way to make sure your
gear
-> is
-> -> still in good shape before you go airborn again..
-> -> I need guidance starting with how to jack up the airplane. As I
wrote
-> -> there is no outward damage but something is making a lot of "dragging
-> tin
-> -> can" noise, pretty loud too when I taxi. A visable movement of the
tire
-> -> forward and reverse also as I wrote. Of course I've searched the
-> -> entire "list"! Not much help to me to read "how easy it was to
repair",
-> when
-> -> what I need is a step by step or even a scanned copy of the drawing
-> the
-> -> landing gear drab bracket area, so I can see what is on the inside.
Tks
all
-> -> caltrac@frontier.com
