[rebel-builders] First amphib flight
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 9:24 pm
Way to go, Ken! I had no doubt you'd be having fun. :)
On Fri, Jun 18, 2010 at 11:11 AM, Ken <klehman@albedo.net> wrote:
Thank you to all the guys who forwarded their weight figures. It was
appreciated.
Had some fun splash'in about this morning.
3.5* throat is looking good so far. (Well after I motor boated around
the lake on the step to get used to the nose so high). It breaks the
water around 41 knots. Takeoff distance seemed pretty good but I did
have at least 5 knots of wind.
Climb at close to gross was 570 fpm which corrects to about double the
minimum required.
Now we're having fun :)
walter.klatt
Post by walter.klatt » Sun Feb 19, 2012 9:24 pm
Congrats, Ken. You're going to have some real fun now.
------Original Message------
Sender: mike.davis@dcsol.com
To: rebel-builders
ReplyTo: rebel-builders@dcsol.com
Subject: [rebel-builders] First amphib flight
Sent: Jun 18, 2010 11:11 AM
appreciated.
minimum required.
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 9:24 pm
That's great Ken. Will you post some pics?
Subject: Re: [rebel-builders] First amphib flight
Date: Fri, 18 Jun 2010 18:55:56 +0000
To: rebel-builders
appreciated.
minimum required.
Hotmail is redefining busy with tools for the New Busy. Get more from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_2
Post by Wayne G. O'Shea » Sun Feb 19, 2012 9:24 pm
Have fun Ken!!!
Remember to let it run a few plane lengths at neutral stick before pulling
back to get up on step.. otherwise you will delay your take off as the back
spreader bar will bury under water.
To: "rebel-builders" <rebel-builders@dcsol.com>
Sent: Friday, June 18, 2010 2:11 PM
appreciated.
minimum required.
Post by Ken » Sun Feb 19, 2012 9:24 pm
OK I uploaded two pics.
Tried using cylindrical boat bumpers on a dock but they float too high
and want to rest on the side skins instead of the chine. Unless someone
has a better product or idea I will try punching a hole in them and
partly filling them with water. That would allow draining them after use.
At heavy weights I seem to be burning 19 liters per hour (5 usgph) at
about 88 mph. (4400 rpm and 22"MAP on the soob) That's about 15% or so
higher burn than on wheels at similar weight. After a couple of tweaks I
will see how it is at higher power. Haven't changed the prop.
