[rebel-builders] cable guide rivets
Kirk Palmer
Post by Kirk Palmer » Sun Feb 19, 2012 9:19 pm
Those are the right rivets.
Kirk
773E
Date: Wed, 31 Mar 2010 23:35:47 -0700
Subject: [rebel-builders] cable guide rivets
The manual (Ch.20, p. 39) says to attach the RG-1 cable guides with RR-7408
alum. rivets. Is that correct? The RR-7408's I have are 5/8", which seems
too long. It looks like the max. grip required anywhere would be at most
half that or less, or 1/4" - 5/16". They appear to have aluminum mandrels,
so maybe the sleeve is extra soft too, and will compress a lot?
254R
IM on the go with Messenger on your phone
http://go.microsoft.com/?linkid=9712960
Post by Wayne G. O'Shea » Sun Feb 19, 2012 9:19 pm
I use RV1414's Ron! I'd like them to stay put..
Sent: Thursday, April 01, 2010 2:35 AM
RR-7408
254R
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 9:19 pm
That's what I was thinking, Wayne. Properly routed, there's not supposed to
be a lot of load on these, but I had an experience with a rudder cable guide
pull-out failure... which immediately reduced rudder control to mushy at
best, induced major tailwheel shimmy, etc. Not fun.
254R
On Thu, Apr 1, 2010 at 6:07 AM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
RR-7408
mandrels,
254R
Imparitive that the last guide before (or the first one after! ;O) ) the
rudder pedals is riveted TO the carrythru upright.. and not into the .020
corner wrap. I've had that guide pull out while doing dual on a Rebel. Also
make sure, if you aren't putting pulleys at the cabin to cone transition
(like you should), that the guide is riveted into the bulkhead flange there
and not just the inner wrap.
Sent: Thursday, April 01, 2010 1:45 PM
Subject: Re: [rebel-builders] cable guide rivets
guide
254R
RR-7408
seems
most
mandrels,
254R
Ron Shannon
I'm putting pulleys both those locations.
However, I am still slicing and dicing whether to use a pulley or only a
well-placed Delrin block fairlead on the last bulkhead before the hole. Any
way you look at it, the cable takes a significant turn there. Do Canadian
inspectors require a pulley back there, and if so, how is it usually
mounted? I'll probably just use the fairlead on the bulkhead (easier,
lighter) but still would like to know how pulleys have been mounted back
there -- if they have.
254R
On Thu, Apr 1, 2010 at 8:20 PM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
Will you have any leg room if you use a pulley at the carrythrough?? Not
necessary if you get your rudder pedal ends as far outboard as you can.
I've never had, or heard of, an inspector asking for pulleys back before the
cable goes out thru the cone side to the rudder. It's the same amount of
deflection as the cabin to cone transition.. but at least it's pushing down
on the guide and not trying to pull it off the floor boards.
Sent: Thursday, April 01, 2010 11:38 PM
Any
254R
Also
there
Post by Walter Klatt » Sun Feb 19, 2012 9:19 pm
No pulleys at all on my rudder cables. The front ones on the door posts take
the greatest pressure with the turn in direction there, but I just lube them
once in a while, to keep them working smooth and light. I do have guides on
the exits of the holes outside the tail cone at the back, which is something
my inspector asked for, even though they were perfectly centered through
those holes.
G. O'Shea
Sent: Thursday, April 01, 2010 8:49 PM
Any
254R
Also
there
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 9:19 pm
Hey Ron, I owe you another visit.
I too worried about the exit and routing of the rudder cables. I like what I
got and will drop by with the next break in the weather and work.
The best advice I got when laying out the cables was to estimate where the
exit hole should go, drill a small hole, route some hardware store steel
cable initially to the rudder horns and then let it saw through the aluminum
until it finds its natural resting place. If you do even a half-way descent
effort at eyeballing the location, the cable will only cut a 1/4 inch gash.
And you'll need that exit hole size enlarged anyway.
Just kidding.
But, don't overthink the problem. It's only aluminum. If you need a patch
aka doubler after it's done, it will be hidden by the rudder cable fairing
that you should install (Aircraft Spruce part).
N645E
P.S. Easy for me to say after spending way too many hours worrying about
this same problem.
Shannon
Sent: Thursday, April 01, 2010 10:45 AM
254R
RR-7408
seems
mandrels,
254R
Ron Shannon
I'm not going to do a pulley in the back, forward of the hole. There I will
use a Delrin block fairlead on the bulkhead frame like Charlie did. I think
that angle can be minimized, and the loads there are contained inside not
only the fairlead, but also the bulkhead frame itself. I will also have
pulleys where the fuse angles in, at the back of the baggage area, as Wayne
reminds.
At the forward door post, I didn't actually measure the angle from rudder
pedal to the door post (yet) but it looked like more than 3 deg. to the
unaided eye. Mostly, it just looked like too much -- even if the first
fairlead was located halfway back under the door. Before coming back to the
computer and this email a few minutes ago, I finished installing the left
forward pulley and, notwithstanding the advice, which I really appreciate,
I'm very glad I did. Looking at that angle the decision was not difficult.
There are at least three reasons I wouldn't do this any other way, all
arising from personal experience, which may not be significant to others.
Reason #1: Last summer I got to do some super duper spin recovery & unusual
attitude training with Master CFI Rich Stowell, who wrote the book on the
topic. (http://www.richstowell.com -- highly recommended.) Flying in his
Decathlon, doing various spins for a couple hours from different entries, I
quickly learned the desirability of a rudder cable that you can really stomp
on when you get the, uh... urge. As RIch was fond of saying, "Stomp on it
like your life depends on it... because it does."
Reason #2: As mentioned earlier, I've also experienced what happens when a
fairlead fails and the cable goes limp. Not pretty, don't want to go there.
So even though with no pulleys at all Walter continues to lead a charmed
life [which, as a truly great guy he surely deserves!!] -- IMHO fairleads
are for wires to slip through, not for any kind of twisting side loads. A
fairlead failure is most likely to happen when you need it most. Stomp.
Reason #3: . It's something I don't want to worry about when I encounter
some unexpected wake turbulence and the plane is suddenly upside down, down
low. Been there. Stomp.
Yes, forward pulleys add a little weight but... it is a control system after
all, and for me, an extra smooth, heavy duty, worry free control cable is a
personal design requirement -- worth beefing up a little.
I also saw a similar (but cleaner) installation of forward door post pulleys
on Craig Wall's web site (http://www.alaskanrebel.com -- great workmanship
and info there!) and it looked so super that along with the all above, the
forward pulley decision was pretty much a no brainer -- to me.
The left forward pulley doesn't interfere with leg room at all, because it's
a good deal smaller than the aileron bell crank underneath. I haven't
installed the right side yet, but holding the parts in place, the pulley is
small, only extending off the wall at most another 1-1/4" more than the
angled cable would otherwise, and I don't think it will be a problem.
Eric, as you know, we would love to have you visit whenever you can. Fine
cuisine, luxurious accommodations, and valet service will be provided, of
course. :)
254R
aluminum
Just kidding.
N645E
this same problem.
Shannon
guide
254R
RR-7408
seems
most
mandrels,
254R
Ron Shannon
FWIW, measurement this morning indicates the cable angle from left rudder
pedal to the pulley mounted at the left door post is approx. 9 deg.
Bypassing the pulley, the angle from rudder pedal to my first cable guide,
located back almost half way along the door sill, is still approx. 7 deg.
For comparison, the angle where the fuse turns in at the rear baggage
bulkhead looks to be roughly 11 deg. (Of course, in addition to load on the
cable guide or pulley, turn radius affects cable wear.)
The end of the left rudder pedal is 1-1/2" from the rear flange of the small
triangle gusset on the side wall. The cable eye on the pedal is inboard
another 1/2" or so.
On Fri, Apr 2, 2010 at 12:02 AM, Ron Shannon <rshannon@cruzcom.com> wrote:
... I didn't actually measure the angle from rudder pedal to the door post
(yet) but it looked like more than 3 deg. to the unaided eye. Mostly, it
just looked like too much -- even if the first fairlead was located halfway
Bob Palmer
Post by Bob Palmer » Sun Feb 19, 2012 9:19 pm
It is great to have the varied opinions that come out on this board and so
in that spirit I will offer mine.
I don't plan to do any stomping, I will save that for the Hoe-Down on
Saturday night, and I will do without the pulley add-on's.
Getting back to the original question. Because were short a couple of
"delrin" fairleads we went down to our local hobby shop and picked up some,
by appearance, identical ones that are for a model airplane. In fact the
appearance of all of them seems to me, suggests that they are not actually
"delrin" but delrin-like. If you ask me they look like they are somewhat
harder and capable of fracture and I would suggest that it could be the
reason for the all aluminum and larger rivet. Secondly, I don't believe I
will need to live a "charmed life" just to stick to the original plan.
....Just my opinion.
Bob 773E
Sent: Friday, April 02, 2010 12:02 AM
will
think
reminds.
unusual
stomp
there.
down
after
pulleys
it's
is
course. :)
254R
what
aluminum
descent
gash.
Just kidding.
fairing
N645E
this same problem.
Shannon
guide
254R
seems
most
mandrels,
The cable guides are made from Nylon 6 (not acetal/Delrin). I have 25 years
as the co-owner of an injection moulding company to know the difference
.... and yes the ones that MAM supplied are "off the shelf" hobby store
guides for landing gear mounts or the likes. That is a known and has been
for many years.... and there is nothing wrong with their usage for the
purpose at hand.
As for fracture..... haven't seen one yet in 15 years.. and I've installed a
LOT of them. Have seen them ripped out of the floor, yet not broken. The all
aluminum 7408 rivet does not have the the tension pull out capability of the
RV1414 as they don't form a proper "shop" end... and FWIW.. I've never seen
a RR7408 in a kit, so not sure when.. or why... the switch to them was made,
or why. They generally get ripped out when someone panics on the brakes. No
balancer cable between pedals.. so all the extra force while the guy jumps
on both pedals tries to pull the cables straight.. and POP !
If you were building in Canada.. you would have to put pulleys at the cabin
to tailcone transition... if the MDRA inspector is paying attention. They
have been snagging that issue in Ontario since 1994!
Sent: Friday, April 02, 2010 5:52 PM
some,
Bob 773E
will
think
reminds.
appreciate,
difficult.
unusual
stomp
there.
down
after
pulleys
workmanship
it's
is
course. :)
254R
what
aluminum
descent
gash.
Just kidding.
patch
fairing
N645E
this same problem.
Shannon
guide
254R
seems most
Ron Shannon
I agree the relative brittleness of the factory-supplied RG-1 cable guides
may be the reason for the longer and softer aluminum rivets. If Wayne
doesn't think they'll break from RV-1414's, that works for me. My references
to Delrin were always to a custom flat fairlead Charlie used at the last
position aft, on the bulkhead.
Personally, whenever I consider doing something less than what Wayne insists
I should do -- like have pulleys where the fuse turns into the tail -- I
first look around for all kinds of magic charms, talismans, incantations,
etc. Usually I just give up and do what he says anyway. :)
My reference to my good friend Walter's charmed life without any pulleys was
intended wry humor, of course. Walter is a fine pilot and even better person
who knows what he's doing with his very fine airplane, which I have admired
more than once.
Actually though, he does live a bona fide charmed life, if only for other
reasons. Flying his Rebel amphib hither and yon in the fabulous BC mountains
all the time... definitely a charmed life. May we all be so lucky.
Bob 773E
Hey, Ron, I do feel privileged, and try to lead a "charmed" life. And that
is all because I have a Rebel amphib. If it was just on wheels, I would only
be privileged... <g>
As for those guides, I was down at my hangar today again to check out those
angles, and yes, that one at the back of the cabin where it enters the tail
cone is a pretty sharp turn, too. But like I said, I do lube them there, to
ensure smooth and light operation.
Because mine is a float plane, the rudders get extra work sometimes, if I
cut my power too early coming into a dock, and need a little extra
propulsion to make it. And don't laugh, guys, it actually works very well,
as the water rudders act like a fish's tail, and I don't have to get out the
paddle. Unless it is windy, but then my paddle probably won't do it
either...
I can see what Wayne says, though, if you stomp on both rudders when
braking, you could put more pressure on those guides. But otherwise, there
really is very little resistance on those rudder cables.
Good to hear you talking about these things, Ron, as it means you actually
are getting close to flying. Keep at it...
Shannon
Sent: Friday, April 02, 2010 3:26 PM
more than once.
some,
Bob 773E
craig
Post by craig » Sun Feb 19, 2012 9:19 pm
My kit, which is #207, purchased originally in late 1992 came with a bag of
7408 rivets. Craig
Sent: Friday, April 02, 2010 2:23 PM
years
purpose at hand.
all
seen
made,
No
jumps
cabin
so
some,
actually
Bob 773E
will
think
not
reminds.
rudder
left
appreciate,
difficult.
others.
unusual
his
entries,
stomp
it
there.
fairleads
A
down
after
is
pulleys
workmanship
it's
is
Fine
course. :)
254R
