[rebel-builders] prop flange types
Post by Walter Klatt » Sun Feb 19, 2012 9:03 pm
You should look at the Vans fiberglass spinners. I did this on my last one,
and much easier than my first aluminum Murphy spinner. You need to match up
your prop hub thickness, though, as with any spinner. to order the correct
one. SAE 2 is the normal bolt pattern for Lycs. What prop do you have?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jones,
Michael
Sent: Friday, February 05, 2010 8:04 AM
Subject: [rebel-builders] prop flange types
now that i have a prop for my lyco 0-320 160hp i am in process of
ordering a spinner
what type of flange is on this engine, from acs catalogue for prop
extensions they only show a sae-2, is this correct
where is good place to find this info
cheers
mike#007
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 9:03 pm
Have a sensenich aluminum
Sent: February 5, 2010 11:22 AM
Subject: RE: [rebel-builders] prop flange types
one,
up
correct
Jones,
Michael
ordering a spinner
cheers
mike#007
