[rebel-builders] cowling
Joe Ronco
DEL: Roger Hoffman used 0.020 for the doors. Go to:
http://tincantimes.dcsol.com/ContentsPage.htm
and check out Pages 5 and 6 for pictures of Roger's cowl.
Joe R
279R
Schmucker, Del
Sent: Tuesday, March 11, 2008 9:34 AM
Subject: [rebel-builders] cowling
I will be soon replaceing my Murphy Speed cowling over my Subaru with
a 4 door metal cowling. I am wondering what other have used for metal.
Did you use .020, .025 or 032 for the cowling skins? It would seem that
025 would be the logical choice but just checked and a 172 used 032.
Comments????
Thank you,
Del Schmucker
Information Systems Manager
Keewatin-Patricia District School Board
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
Joe R
279R
Schmucker, Del
Comments????
Thank you,
Del Schmucker
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
www.kpdsb.on.ca
Hi Del
The Cowling kit from MAM used 0.020 which worked fine for me. Heavier
stuff might be more difficult to wrap around the curves unless you have
rollers available. MAM suggested bending the 0.020 around a tube
manually. I did use rollers but some guys just leave it flat. Don't know
if that eventually causes paint problems from flexing it. I used
doublers around my cowl latches on the top doors but not on the bottom
doors that use the piano hinges. I like my cowl latches but the piano
hinges work better than I expected and were a lot less work.
I've heard other guys mention using 0.025
Comments????
Thank you,
Del Schmucker
Dale Fultz
On the Moose I used .025 for the second set of doors I made the first ones
from .020 and with the six cylinder spaning a larger area didn't seem
sufficient so I made another set of heavier material and seem to work so for
in paint shop now.. Dale SR-033 N269DF
Jim Cole
Hi Del, I found the 032 too hard to work with to get the right curve without
the proper tools - but with the 025 I could use a piece of 2" pipe in the
vice and sort of roll the pieces over the pipe to get the curve to fit. The
four doors end up being relatively small with hinge support and nose bowl
and firewall support as well so the 025 worked for me.
Jim
R333
Jim
R333
Comments????
Thank you,
Del Schmucker
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
www.kpdsb.on.ca
Del,
What's the story on the cowl you are removing? For sale? Trade? Craig
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jim
Cole
Sent: Tuesday, March 11, 2008 9:25 AM
Subject: Re: [rebel-builders] cowling
Jim
R333
Cole
Jim
R333
Comments????
Thank you,
Del Schmucker
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
www.kpdsb.on.ca
Charlie Eubanks
[rebel-builders] Cowling
Kirk
If you are just looking for the weight mine is still hangar in the hangar
and is 15 Lbs. but not for sale.
Charlie
Sent: Saturday, January 23, 2010 6:39 PM
Subject: [rebel-builders] Cowling
Charlie
Does anyone have a Murphy cowling that hasn't been cut/altered yet? If so,
how much does it weigh?
Kirk Palmer
773E
Kirk Palmer
Thanks, yeah I was only looking for the weight. My dad and I have had to re-do the cowling because it doesn't fit our engine. Forgot to weigh the thing before we started so I could compare the finished product.
Reinvent how you stay in touch with the new Windows Live Messenger.
http://go.microsoft.com/?linkid=9706116
Subject: Re: [rebel-builders] Cowling
Date: Sat, 23 Jan 2010 19:10:37 -0600
Kirk
Charlie
Kirk Palmer
773E
Charlie Eubanks
Kirk
That weight includes a 1-1/2 flange around the entire main opening that
must be removed. Have no idea what that would weigh.
Sent: Saturday, January 23, 2010 7:26 PM
Subject: RE: [rebel-builders] Cowling
_________________________________________________________________From: charlie@troyairpark.com
Kirk
Charlie
so,
Kirk Palmer
773E
Kirk Palmer
Yes I remember cutting that thing off. Thanks for the info Charlie
Kirk
Say Happy New Year with Messenger for Mobile.
http://go.microsoft.com/?linkid=9706117
Kirk
Date: Sat, 23 Jan 2010 21:40:03 -0600
Kirk
Kirk
Charlie
