[rebel-builders] doubler
Post by Walter Klatt » Sun Feb 19, 2012 8:50 pm
Ron, I can't remember how you did your doors and main latches. But the top
ones are the same material as the main ones on the side.
However, don't install the top one in the centre of the window like I did,
because the fronts like to lift away at higher speeds. I had to install
velcros on the front to fix that. Best to install it closer to the front.
Shannon
Sent: December 10, 2009 6:44 PM
Subject: [rebel-builders] doubler
Hi Brian,
I'm not sure I understand what you're referring to. Or rather, I'm sure I
don't. :-) Perhaps it would help if you gave me the (URL) link to the
photo on my site that you noticed...? Happy to answer if I can, once we get
on the same page, er, photo. :-)
On Thu, Dec 10, 2009 at 6:10 PM, Brian Bridgewater <ecomind@ymail.com>wrote:
To Ron Shannon Hello Ron I have Rebel 274R I was just browsing
your foto's and noticed a doubler installed to the rear of the door frame
in
front of the ailron box as im just repairing my wing root attachment point
just above I wandered if this is a known mod as I found this area to be
very
weak when deriveting, hope you don't mind me asking regards Brian.
craig
Post by craig » Sun Feb 19, 2012 8:50 pm
I believe Roger Hoffman used two latches on the top of the door. Might be a
better answer than one toward the front. Here's his link; you'll have to
look through it to find them.
http://tincantimes.dcsol.com/
Brian Bridgewater
Post by Brian Bridgewater » Sun Feb 19, 2012 8:50 pm
Hi Ron
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:50 pm
Brian,
I'll contact you off list to see if I can help.
On Fri, Dec 11, 2009 at 4:55 PM, Brian Bridgewater <ecomind@ymail.com>wrote:
Hi Ron Thanks for getting back to me the PC is new to me URL what is? On
your photo's Blog page 6 last pic, overlapping corner gusset top r/h corner
of pic, many thanks Brian.
