[rebel-builders] Adjusting Aileron/Flaps
Post by Ken » Sun Feb 19, 2012 8:40 pm
A few other guys have mentioned this as well Charlie.
It might be due to the aileron horns being riveted on in slightly
different positions or the horns on the torque tube riveted on in
slightly different positions. If that is the case you may have to live
with it. Markedly different length push rods on the aileron horns will
also do it.
Another thing that could do it is if the mixer bellcrank is backwards.
That bellcrank is not quite symetrical and it is easy to install it
backwards.
On a separate issue:
With your modified bellcrank, do you notice any affect on the elevator
when you go full left or right aileron. I have been hesitant to make
that mod.
Charlie Eubanks wrote:
[quote]Hello all
I have a question on flap deployment.
Thanks to Ron Shannon I now have the correct length of Teleflex cable
installed in my Rebel. After modifying the hole location from 2-3/8" to 2"
on the newer bell crank I am now able to get 4" up (16.7
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 8:40 pm
Hi Ken
You are right in that there are a number of things that could contribute to
the unevenness and difficultly in getting the controls properly rigged. I
followed all the steps in the manual I thought but it still a head
scratchier. My smaller push rods and the 2" torque tubes in the fuselage are
just clecoed so I can still do some adjusting, if I can figure out what to
do next.
The other item in your message about the mixer bell crank was a BIG surprise
to me. I can find nowhere in my manual any mention of the mixer bell crank
having a uneven hole pattern or that it could be installed backwards. I
assumed it to be symmetrical. I just checked the hole pattern and you are
correct. The holes for the two smaller push rods are a 1/8" different in
distance from the hole for the 1" push rod. If this info is a factor in the
successful rigging of the controls, on which side does it go? Was there
somewhere in the Rebel files an alert posted I may have missed? I guess it
still not to late but this info may have saved a lot of time and head aches
had I have known.
Sorry I can't answer your question about the modified bell cranks effect on
the elevator. I have yet to install the elevator or rudder cables. I would
be interested in your concern however.
Thanks for the heads up on the mixer bell crank.
Charlie E. 802R
Sent: Sunday, October 18, 2009 8:37 PM
Subject: Re: [rebel-builders] Adjusting Aileron/Flaps
[quote]A few other guys have mentioned this as well Charlie.
also do it.
backwards.
that mod.
[quote]Hello all
2"
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 8:40 pm
Hi Charlie,
The positioning of the Mixer (CC-48-2) is not well defined in the builder's
manual (much like many other sections of the manual) but we persevere and
move forward. The correct forward horn position of the Mixer is, when
measured from the center of the 1" hole to the 1/4" hole is *1.8"*. The
lesser measured distance from center to center is 1.7" (this horn faces
aft).
Another factor in aileron/flapperon deflection is the angles measured at the
mixer and vertical P/P tubes, the angles measured at the bottom must be the
same at the top mounting position as well (horns & 2" tubes).
Jeff
On Mon, Oct 19, 2009 at 11:09 AM, Charlie Eubanks
<charlie@troyairpark.com>wrote:
[quote]Hi Ken
are
do next.
surprise
had I have known.
Charlie E. 802R
also do it.
backwards.
that mod.
[quote]Hello all
2"
Charlie
The archives has info on the mixer but sounds like Jeff has answered
that. I would not have remembered which way it goes but I do remember
working out the geometry at the time.
My curiosity about modifying the forward bellcrank would only apply if
the bellcrank was not centered on the control tube. It would be offset a
bit if I just drill a new hole and don't move the bellcrank. My
elevators are very light to move and fairly sensitive but it takes firm
side pressure to get full aileron in flight when the flaperons are down.
So just drilling the new hole might produce a tendency to move the
control stick forward or aft a bit when I apply aileron. That's my
excuse for not doing it yet anyway ;)
I would not be too concerned about perfection here. A half inch is not
very significant. I should take my own advice eh? Might be annoying when
you extend the flaps if the stick moves sideways but you probably
wouldn't notice after awhile. It is important to make sure the teleflex
cable is tensioned when you rig them though. ie don't rig them with the
teleflex holding the flaperons up or you will not get anywhere near full
extension in flight.
[quote]Hi Ken
do next.
had I have known.
Charlie E. 802R
also do it.
backwards.
that mod.
[quote]Hello all
2"
Charlie Eubanks
Hello Jeff
I have seen your name quite often as of late and you have been very helpful
and right on top of things. Are you the same Jeff that is with Murphy?
Either way I sure appreciate your help. I am still a little confused. I
reversed the mixer bell crank and there are considerable differences in the
control dimension I found.
I just measured the hole pattern of the mixer bell crank that I have and I
hope I can clearly describe the dimensions I found.
From the center of the large 1" hole to the center of each
Jeff Micheal
Hello Charlie,
Sorry I mislead you in the measurements, I should of chosen my words
differently. The measurements I had given are not C to C, but measured from
center line. I will send you my hand drawing of the part (CC-48-2) and its
correct placement as installed in the AC.
Jeff
On Mon, Oct 19, 2009 at 3:44 PM, Charlie Eubanks <charlie@troyairpark.com>wrote:
[quote]Hello Jeff
Charlie Eubanks
Thanks Jeff
I understand I will let you know how it all turns out.
Charlie E.
From: "Jeff Micheal" <westcoastkitplanes@gmail.com>
Sent: Monday, October 19, 2009 8:37 PM
[quote]Hello Charlie,
from
its
Jeff
[quote]Hello Jeff
helpful
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 8:40 pm
Ken,
Can you elaborate a bit on the last paragraph on being sure the teleflex
cable is tensioned. I don't get full extension in flight and it is a
common complaint of rebel drivers - not that affects its flight that
much. I get full extension until the flaperons are wind loaded then
probably less than half.
Garry
Ken wrote:
[quote]Charlie
[quote]Hi Ken
do next.
had I have known.
Charlie E. 802R
also do it.
backwards.
that mod.
[quote]Hello all
2"
Charlie Eubanks
I modified the forward bell crank because I was under the impression that I
would not be able to get enough aileron deflection for heavy cross winds
landings. Since I have no time in Rebels. I have no idea how much more stick
force will be required. I hope not to much. Not sure I understand about
rigging in tension?
Charlie E.
Sent: Monday, October 19, 2009 4:51 PM
[quote]Charlie
[quote]Hi Ken
are
do next.
surprise
crank
it
aches
had I have known.
on
would
Charlie E. 802R
also do it.
backwards.
that mod.
[quote]Hello all
2"
The bulletin with control movement specs says 15 degrees max flaperon
and I get 15 to 18 in flight as long as I slow to about 65 knots or
less. In the zero flap position they hang down at least an inch on the
ground. I have to select reflex to get them to fare with the wing in
order to install control locks on the ground. Mostly just a matter of
installing the cable tight enough so you have the room to adjust things.
The mixer lever arm has to be tight enough in the slot that it doesn't
twist too much. If you notice the outer teleflex moving sideways it
doesn't hurt to tie wrap it to the airframe ceiling where possible but
that is very minor. With my slow cruising speed I very rarely use reflex
but they do still reflex almost an inch at the trailing edge.
There is another thing going on on my aircraft. Perhaps my 3 blade Warp
prop in inefficient or something but the more power I have on, the more
the flaperons want to deflect with the spiraling prop wash and roll the
aircraft to the left. That and P factor, and a bit of engine torque,
sometimes surprises other pilots during takeoff. It also means that I
need right aileron trim in cruise to keep the flaperon deflection
neutral. This is heresy here but I think I'd like separate flaps as long
as I could still drop the ailerons like Steve Sloan does. That would
also reduce the required stick force to get full aileron deflection and
harmonize the controls better during crosswind ops IMO.
Garry Wright wrote:
[quote]Ken,
Garry
Ken wrote:
[quote]Charlie
[quote]Hi Ken
do next.
had I have known.
Charlie E. 802R
also do it.
backwards.
that mod.
[quote]Hello all
2"
Garry Wright
Thanks Ken. I will check out these things and may make some adjustments.
I've never had a crosswind problem with mine and we do get lots of wind
around here. Probably as windy here as anywhere in Canada.
With my prop, I used to use EGT/CHT indications for leaning and
essentially tried to control fuel consumption and limit it to 7.3 gph
with limited success(O320 150 HP). It usually meant holding rpm to about
2350 at which point you can't get fast enough to use reflex effectively
on floats. With Walter's lead on fuel flow guages I installed one and
now run at my targeted fuel flow with lots of power and higher rpm
(around 2450 to as high as 2600 depending on altitude). That allows full
reflex of course and the gains inherent in that. I won't want to give up
any reflex to gain full downward deflection so my task might be tricky.
Your comment makes it sound like Steve can drop flaps and ailerons
independently - is that correct?
Garry
Ken wrote:
[quote]The bulletin with control movement specs says 15 degrees max flaperon
Garry Wright wrote:
[quote]Ken,
Garry
Ken wrote:
[quote]Charlie
[quote]Hi Ken
do next.
had I have known.
Charlie E. 802R
also do it.
backwards.
that mod.
[quote]Hello all
2"
Yes Steve can drop flaps and ailerons independently.
I might be seeing a similar power thing as you in that I'm likely
turning the Warp slower than it was really designed for. But it is nice
and quiet.
Garry Wright wrote:
[quote]Thanks Ken. I will check out these things and may make some adjustments.
Garry
Garry Wright wrote:
[quote]Ken,
Garry
Ken wrote:
[quote]Charlie
[quote]Hi Ken
do next.
had I have known.
Charlie E. 802R
also do it.
backwards.
that mod.
[quote]Hello all
2"
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 8:40 pm
I can go surprisingly slow with my reflex, down to near 80 mph if I am not too heavy. I often do slow cruises around the lake when taking people for rides, between 80 and 90 mph, and burn as low as 5 US gph. At some point, though, as I slow down, the nose starts to rise, and I have to put it into neutral. I immediately lose a few mph then, and have to increase throttle to maintain speed. It may be that the VGs help here, too. Can't remember, though, how slow I could go in reflex before I had them.
Again, I have no problems in crosswinds now that I have the VGs. They also really help with float ops, as do the full span flaperons. Float angle is important too, and take off technique may have to vary a bit depending on weight and hp.
Ken, don't know if you still lay over in Vancouver sometimes. But you should come for a flight with me. My plane is quite different than yours, and it might interesting to compare as you continue to refine yours.
Date: Tuesday, October 20, 2009 9:50 am
likely
But it is nice
and quiet.
adjustments.>
lots of wind
7.3 gph
rpm to about
effectively
one and
rpm
allows full
to give up
be tricky.
ailerons
Garry
flaperon
knots or
inch on the
wing in
matter of
adjust things.
it doesn't
sideways it
possible but
use reflex
blade Warp
on, the more
and roll the
torque,
means that I
deflection
flaps as long
That would
deflection and
Garry Wright wrote:
the teleflex
it is a
flight that
loaded then
answered
do remember
only apply if
would be offset a
bellcrank. My
it takes firm
flaperons are down.
move the
That's my
inch is not
annoying when
probably
the teleflex
them with the
anywhere near full
could contribute to
properly rigged. I
still a head
in the fuselage are
figure out what to
was a BIG surprise
mixer bell crank
backwards. I
pattern and you are
1/8" different in
is a factor in the
go? Was there
missed? I guess it
time and head aches
cranks effect on
cables. I would
slightly>>>>>> different positions or the horns on the torque
tube riveted on in
have to live
aileron horns will
is backwards.
install it
the elevator
hesitant to make
Teleflex cable
from 2-3/8" to
(16.7
Garry Wright
Thanks Ken. That must be an interesting design Steve has.
I find that with this wing, getting altitude loss is not much of a
problem - unless you get too much : ). Getting slower - if more flap
will do that - is a good and worthy objective.
Garry
Ken wrote:
[quote]Yes Steve can drop flaps and ailerons independently.
and quiet.
Garry
Garry Wright wrote:
[quote]Ken,
Garry
Ken wrote:
[quote]Charlie
[quote]Hi Ken
do next.
had I have known.
Charlie E. 802R
also do it.
backwards.
that mod.
[quote]Hello all
2"
Garry Wright
Yes - 80 mph CAS is about the lower limit for reflex and I think most
rebels experience that. Certainly mine and John Petersons were similar.
At higher altitudes like above 4000', 80 mph CAS requires more than 2350
rpm on an O320. At sea level, 80 mph is still a low rpm exercise.
Garry
likely
But it is nice
and quiet.
adjustments.>
lots of wind
7.3 gph
rpm to about
effectively
one and
rpm
allows full
to give up
be tricky.
ailerons
Garry
Ken wrote:
flaperon
knots or
inch on the
wing in
matter of
adjust things.
it doesn't
sideways it
possible but
use reflex
blade Warp
on, the more
and roll the
torque,
means that I
deflection
flaps as long
That would
deflection and
the teleflex
it is a
flight that
loaded then
answered
do remember
only apply if
would be offset a
bellcrank. My
it takes firm
flaperons are down.
move the
That's my
inch is not
annoying when
probably
the teleflex
them with the
anywhere near full
could contribute to
properly rigged. I
still a head
in the fuselage are
figure out what to
was a BIG surprise
mixer bell crank
backwards. I
pattern and you are
1/8" different in
is a factor in the
go? Was there
missed? I guess it
time and head aches
cranks effect on
cables. I would
tube riveted on in
have to live
aileron horns will
is backwards.
install it
the elevator
hesitant to make
Teleflex cable
from 2-3/8" to
(16.7
