[rebel-builders] Vibration
Post by Bob Patterson » Sun Feb 19, 2012 7:51 pm
Hmmmm...... might be missing a screw on one of the tail
fairings, or wing fairings, ... or a bit of loose rubber edging ???
How about slack in the water rudder cables allowing
them to hit the float ?? .... or slack in the X brace wires ?
... or brake line tubing ...
I had a piece of rubber edging come out at the front
of the wing root fairings on FOKM - sounded like the
engine was about to throw a rod !! It was beating on the
top of the wing ... turned back & landed at Chilliwack ASAP !!
Time for a real close inspection - look for wear from
moving fairings or cables ....
bobp@prosumers.ca
On Saturday 09 August 2008 03:25, Garry wrote:
Last week, flying with my wife aboard, we encountered a light gust
(which my wife did not notice) which was either caused by or was the
cause of the onset of a fairly loud vibration noise. This noise seemed
to emanate from the rear of the aircraft, and was loud enough to make me
decide to land urgently which I did.
The noise sounded like a very rapid oil-canning. ie: the sound of a
piece of sheet metal flexing rapidly as a result of stimulation by the
wind. It does not appear to be a control surface because I feel nothing
in any of the controls. The noise in subsequent tests shows up at 60 mph
IAS (approx) and seems fairly constant regardless of airspeed, rpm or
other stimulations.
Nothing was changed in the past 12 hours of operation prior to the onset
of this noise. Earlier the floats had been put back on replacing the
wheels. I have spent considerable effort chasing this unnerving
phenomena. Has anyone else any similar experience and recommendations?
Garry
068R
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 7:51 pm
I had a rapid tapping/ light banging noise on take off one day and landed
quickly because it was unusual - Peter eventually found it ...it turned out
to be the end of a piece of rubber trim that had come out from under the
wing root faring and it was slapping on the fuselage.
It happened again a few months later (because I keep forgetting to glue it
down) Tom, Peter, and I now refer to it as the "French River Flap".
Good luck
Jim R333
other stimulations.
Garry
068R
Post by Ken » Sun Feb 19, 2012 7:51 pm
You probably already did it but for giggles I'd also grab all the
control surfaces to check for bearing play and also for up down movement
of the stab at the tips and at the fuselage forward mount. Some Rebels
have more free play in the stabilizer struts than I like.
other stimulations.
Garry
068R
Garry
Post by Garry » Sun Feb 19, 2012 7:51 pm
Thanks Ken. I'm in the midst of putting new bushings, the two
reinforcement types, and adding some reinforcements aft of the hinge
point on the tips to make up for the loss of the ST40 rivets which have
pulled out and cannot be replaced. The bushings were rotating in the
stays which is not good at all. The tips were pretty sloppy and could be
doing it but probably not. There seems to be no relationship between
airspeed or elevator position or engine rpm and the tone of the
vibration. Points to a simple surface vibration I think.
Garry
other stimulations.
Garry
068R
Garry
Thanks Jim. That was the first thing I thought of after getting on the
ground. Unfortunately that was not it(at least the one I thought it
might be). One thing though, is the rubber on the lower fairing on one
of the elevators has disappeared. Could be that fairing thrashing around
I suppose and the rubber may have fallen off in mid-flight, which would
explain the sudden onset. I will try to get some replacement rubber. Any
idea on sources?
Garry
Good luck
Jim R333
other stimulations.
Garry
068R
Garry
Thanks Bob. My thoughts also. I really thought that was it at one point
but....
Garry
Jim Cole
Aircraft Spruce has quite a collection in their catalog - What width are you
looking for to match the other trim?
Jim
idea on sources?
Garry
Good luck
Jim R333
other stimulations.
Garry
068R
Garry
Its 3/8" stuff Jim. Speaking of ACS
Start of Rant!
When ACS opened in Toronto it was a boon for Ontario folks I think. But
we in the west got royally shafted. For me to buy 1" of this trim from
ACS would require a $50 shipping bill from ACS. It is cheaper to have it
shipped by air from the California outlet than from TO. Not only that,
they only accept returns from Canada via TO and then lose them in the
return process - even when they were purchased from the US in US$ on US
credit cards. Nice huh. I buy from them in the US but never when in
Canada any more. In other words I very much feel cut off from a sensible
supply source in the summer when in Canada. And it goes way beyond this
description.
End Rant!
Sorry about that - I usually don't rant but this one was well earned by
ACSTO for the last run around I got from them.
Can you suggest any other source?
Garry
Jim
idea on sources?
Garry
Good luck
Jim R333
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 7:51 pm
FWIW, Wicks (http://www.wicksaircraft.com/) also has a selection of rubber
edging. Good luck.
Garry
Garry
Thanks Ron. What did you search their site for when you looked - I can't
seem to find it.
G
edging. Good luck.
Garry
Ron Shannon
Depends on just what you're looking for, of course, but "rubber channel"
will get you to some. The paper catalog is nice to have in the library. :-)
seem to find it.
G
rubber
edging. Good luck.
Dave Ricker
Post by Dave Ricker » Sun Feb 19, 2012 7:51 pm
Garry
Do you know about Spaenaur in Kitchener? Thay probably have something that would
do the trick, Quickedge might be it
http://www.spaenaur.com/products.asp?PageID=K.
elite583.cjb.net
Start of Rant!
description.
End Rant!
Garry
Jim
idea on sources?
Garry
David A. Ricker
Fall River, Nova Scotia
Canada
Garry
Thanks Dave. Lots of detail there.
Garry
Dave Ricker wrote:
Garry
elite583.cjb.net
Start of Rant!
description.
End Rant!
Garry
Jim
David A. Ricker
Canada
