[rebel-builders] Rebel - tapered corner wraps (Fus-10) over
[rebel-builders] Rebel - tapered corner wraps (Fus-10) over or unde
Post by Bob Patterson » Sun Feb 19, 2012 7:47 pm
Guess there's less chance of snagging pants if the triangle
is INSIDE .... no biggie, though.
Might be worth upgrading that triangle to .025, if it
isn't already ... that would make that whole section
all .025 ..
bobp@prosumers.ca
On Friday 08 August 2008 15:28, bransom@dcsol.com wrote:
Sounds good. I was really scratching my head trying to figure this out
until I found the picture, but with no mention in the manual, I'm grateful
for the advice. I may end up with the triangle Fus-25 outside of the
rectangle Fus-26.
Oh, yeah, and I've done those O mods you mentioned, thanks. I shoulda
said Fus-70. I've made my own .025 Fus-70 pieces btw. Not hard to do.
-Ben
Hi Ben !
Not sure it really matters ..... certainly looks OK
this way, and can't remember EVER seeing one OVER
the FUS-26 -- but I'm no expert.
The pic reminded me, though, that one Ontario mod
is to increase FUS-26 to .032 or .040, and add a vertical
channel or 2 behind it - or pieces of stringer..
Also, if you have a choice, it would be better to use
FUS-70's (.025) for ALL of the 8 corner wraps ....
might save some grief later.
bobp@prosumers.ca
On Friday 08 August 2008 02:26, bransom@dcsol.com wrote:
I'm trying to figure out what the correct (best?) overlap is on the
tapered corner wrap with Fuse-26 and Fus-25 below the door sill area.
Here's a photo from the Rebel CD to make my question easier to
understand. <a
href="http://mae.ucdavis.edu/ransom/Murphy/20 ... tp://mae.u
cdav is.edu/ransom/Murphy/2008/fuse.jpg</a>
In this the tapered corner wrap is underneath, then the triangle
Fus-25, then the rectangle Fus-26 is outermost. Is this the best way,
or have some found a better layering order?
-Ben/ 496R
