[rebel-builders] LS1 in a Moose on behalf of Steve Bowley
Chris Hodgson
Steve,
Somehow your posting was sent to my junk box which is ironic since I am
thinking of putting an LS2 in my moose. As I don't want to bore everyone
with my questions, could I ask you about some details "off blog"? Thanks
Chris Hodgson chrishodgson@shaw.ca
Kimball
Sent: February 15, 2008 1:51 PM
To: Rebel Builder's List
Subject: [rebel-builders] LS1 in a Moose on behalf of Steve Bowley
I have noticed some discussion regarding the LS engine in a Cessna. I saw
that when it first came out several years ago while I was building my Moose
with a LS 1. I was hoping that when my project was finished that I could
have a reliable aircraft with a cost effective, high performance engine that
would perform as well as a Moose with a M-14. I don't have many hours on
the plane yet to claim reliable, but I have enough hours to claim that the
climb performance is similar to the M14 and the cruise is 125 kts at 21
inches of manifold and 2100rpm at the prop [engine rpm 3800] burning 10-11
gal/hr of auto fuel. I only have 50 hours of flight time on the plane and
hope to get a lot more.
My firewall forward [ engine, mount, cowl, exhaust, all accesories, psru,
computer, radiator] cost $26000 plus shipping. I purchased a 3 blade MT
electric prop for $12500 because it allowed me to use the psru without a
governor and only weighed 55 pounds. The prop was pitched at the factory to
require 350HP to turn at 2500 prop rpm and 4500 engine rpm. The engine at
full throttle turns the prop at 2500rpm which means I am getting 350 HP at
take-off.
I haven't been able to measure my ground roll, but with me and 60 gal of
fuel I estimate it to be in the 350- 450 foot area. I am not too sure of
this at present, but will try to get a better measurement in the future.
My plane weighs 1906 empty. In looking at the M14 empty weights they seem
to come in at any where from 2100-2300. The empty weights for the 300HP Lyc
come in at 1850-1950. So, the concept of auto engines in the MOOSE being
too heavy don't appear to apply. No doubt this engine in a smaller airframe
may not work. At my FAA inspection, my CG came out to be exactly at the
forward limit and with any load addition, it will stay within the CG.
The cooling did present a problem intially, but with ongoing R&D I have the
temps under control. When I was flying in September with OAT of 110F, the
water temp was 200F and the oil was 210F. Now with OAT of 50-70F, the water
runs at 180F and the oil at 160. In the first 50 hours of operation I have
added 2 quarts of oil and I changed the oil at
25 hours. The first quart of oil was added because of a leak of the front
seal which was replaced at the cost of $3.00 and labor.
Presently, the plane will be VFR on wheels and no plans to use floats even
though I installed the float attach points. All the published mods have
been done to the airframe and a Dale Fultz tail spring was used. I have to
say if anybody has a opportunity to use this tail spring, I wholeheartedly
endorse it because it works great in absorbing my not so perfect landings.
I agree that if I had purchased a Lyc or Cont engine, my build time may have
been shorter and I certainly have had some unique problems while getting to
this point in this project. The problems have not been insurmountable, all
you need to continue is time and money. In spite of my problems, the use of
the LS1 and the expense of the MT prop cost me less than a new or factory
reman 300 HP Lyc or Cont engine without the accessories, mount, cowl,
governor, and prop.
I have been flying at every free moment and have modified the cowl during
the test flights, so I haven't been able to paint the cowl. Some rainy day
in Phoenix, I might have time to finish prepping and painting the cowl. I am
waiting until I get the cowl painted to send pics to the Moose website to
document that it is done.
Obviously, I don't have that magic number to prove it is reliable and would
suggest that anyone considering the same type of endeavor do their homework
thoroughly. This has been a huge project and I have made every effort to
ensure that it will be successful. Most of the joy has come with flying and
has made the many thousand of hours working evenings, weekends, and
vacations seem to be worth the time. This plane, like any plane will be
subject to continous inspections and modifications in order to keep it
airworthy. I hope that I can give the readers of this server an update in
the future, hopefully with continued success.
Steve
Moose/SR #99
Kimball
take-off.
governor, and prop.
Steve
Moose/SR #99
Mike Davis
Please... ask away. You're not the only one considering an LS2.
Sent: Friday, March 07, 2008 4:53 PM
Subject: RE: [rebel-builders] LS1 in a Moose on behalf of Steve Bowley
Steve,
Kimball
Moose
that
take-off.
Lyc
airframe
water
have
have
all
governor, and prop.
day
am
would
homework
Steve
Moose/SR #99
Brian
I'm very interested in the LS1 information in a Moose. Please keep this
discussion on the blog.
Thanks.
Brian
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Chris
Hodgson
Sent: Friday, March 07, 2008 8:53 PM
Steve,
Kimball
take-off.
governor, and prop.
Steve
Moose/SR #99
Thanks.
Brian
Hodgson
Steve,
Kimball
take-off.
governor, and prop.
Steve
Moose/SR #99
Chris Hodgson
Steve,
OK. Since there is some interest - as a background I recently purchased a partially completed Moose. I had looked at them for a number of years and had always considered using an LS series engine for all the reasons we know - high power to weight ratio, relatively inexpensive engine components, fuel flexibility etc. I had also been apprehensive for the usual reasons - unproven technology (mostly the PSRU), time and expense in doing a one off, etc. For these reasons I had planned to put in an IO540 and the consider doing a firewall forward LS while flying the plane. By chance a firewall foward LS2 came up recently on ebay (as everyone may remember) and I bought it for a good price (I hope). The PSRU is a helical geared unit and was flying in a plane for 15 hours. The project was scrapped because the airframe of the aerocomp it was in was apparently over-built by more than 1000lbs making it un-flyable.
So now I have a firewall foreward LS2 and you Steve are the first person I have been able to talk to who is flying what I think I want. I probably have a million questions but I will start with a few so I don't put you off.
How did you choose your PSRU? I looked into the chain drives by Vesta and Robinson but I have to say I was put off by Vesta when they refused to give me the names of anyone using their system.
How did you set up your cooling system? Did you set up a hot water cabin heat system with the coolant?
How did you engineer the engine mount - line of thrust etc?
Did you put in any spark plug /magneto redundancy or rely on the LS dedicated coil per cylinder? (I think I am going to stay with the LS system. I have never had a car die suddenly for ignition reasons but I once had a magneto rotor break on takeoff.)
Thanks in advance for the help,
Chris
Date: Friday, March 7, 2008 7:02 pm
Subject: Re: [rebel-builders] LS1 in a Moose on behalf of Steve Bowley
Chris
since I amSteve,
Somehow your posting was sent to my junk box which is ironicto bore everyonethinking of putting an LS2 in my moose. As I don't wantblog"? Thankswith my questions, could I ask you about some details "offBehalf Of MikeChris Hodgson chrishodgson@shaw.ca
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] OnCessna. I sawKimball
I have noticed some discussion regarding the LS engine in abuilding mythat when it first came out several years ago while I wasfinished that I couldMoose
with a LS 1. I was hoping that when my project wasperformance enginehave a reliable aircraft with a cost effective, highhave many hours onthat
would perform as well as a Moose with a M-14. I don'tclaim that thethe plane yet to claim reliable, but I have enough hours tokts at 21climb performance is similar to the M14 and the cruise is 125burning 10-11inches of manifold and 2100rpm at the prop [engine rpm 3800]on the plane andgal/hr of auto fuel. I only have 50 hours of flight timeaccesories, psru,hope to get a lot more.
My firewall forward [ engine, mount, cowl, exhaust, allpurchased a 3 blade MTcomputer, radiator] cost $26000 plus shipping. Ithe psru without aelectric prop for $12500 because it allowed me to usepitched at the factorygovernor and only weighed 55 pounds. The prop wasrpm. The engine atto
require 350HP to turn at 2500 prop rpm and 4500 enginegetting 350 HP atfull throttle turns the prop at 2500rpm which means I am60 gal oftake-off.
I haven't been able to measure my ground roll, but with me andnot too sure offuel I estimate it to be in the 350- 450 foot area. I amthe future.this at present, but will try to get a better measurement inweights they seemMy plane weighs 1906 empty. In looking at the M14 emptyweights for the 300HPto come in at any where from 2100-2300. The emptythe MOOSE beingLyc
come in at 1850-1950. So, the concept of auto engines ina smallertoo heavy don't appear to apply. No doubt this engine inexactly at theairframe
may not work. At my FAA inspection, my CG came out to bethe CG.forward limit and with any load addition, it will stay withinR&D I haveThe cooling did present a problem intially, but with ongoingOAT of 110F, thethe
temps under control. When I was flying in September withof 50-70F, thewater temp was 200F and the oil was 210F. Now with OATof operation Iwater
runs at 180F and the oil at 160. In the first 50 hoursleak of the fronthave
25 hours. The first quart of oil was added because of afloats evenseal which was replaced at the cost of $3.00 and labor.
Presently, the plane will be VFR on wheels and no plans to usepublished mods havethough I installed the float attach points. All theused. I havebeen done to the airframe and a Dale Fultz tail spring waswholeheartedly> endorse it because it works great in absorbingto
my not so perfect landings.time mayI agree that if I had purchased a Lyc or Cont engine, my buildwhile gettinghave
been shorter and I certainly have had some unique problemsinsurmountable,to
this point in this project. The problems have not beenproblems, the useall
you need to continue is time and money. In spite of myor factoryof
the LS1 and the expense of the MT prop cost me less than a newmount, cowl,reman 300 HP Lyc or Cont engine without the accessories,cowl duringgovernor, and prop.
I have been flying at every free moment and have modified thecowl. Some rainythe test flights, so I haven't been able to paint thethe cowl. Iday
in Phoenix, I might have time to finish prepping and paintingwebsite toam
waiting until I get the cowl painted to send pics to the Moosereliable anddocument that it is done.
Obviously, I don't have that magic number to prove it istheirwould
suggest that anyone considering the same type of endeavor doevery effort tohomework
thoroughly. This has been a huge project and I have madecome with flyingensure that it will be successful. Most of the joy hasweekends, andand
has made the many thousand of hours working evenings,any plane will bevacations seem to be worth the time. This plane, likekeep itsubject to continous inspections and modifications in order toserver an update inairworthy. I hope that I can give the readers of thisthe future, hopefully with continued success.
Steve
Moose/SR #99
Mike Davis
If I'm think of the right motor, that PSRU was built by Rasakti... they make
turbine gear boxes, so it should be a good solid unit.
Sent: Saturday, March 08, 2008 11:34 PM
Steve,
off.
Chris
since I amSteve,
Steve
Moose/SR #99
I can email you the information I got from MAM that gave me what I needed to
position the line of thrust properly. I'll scan it in tomorrow and upload
it to archives. I'll also email it separately to you to save you the
trouble of downloading it.
044SR
Hodgson
Sent: Saturday, March 08, 2008 10:34 PM
Steve,
Chris
044SR
Hodgson
Steve,
Chris
since I amSteve,
Steve
Moose/SR #99
Chris Hodgson
Thanks Mike,
Chris
Kimball
Sent: March 11, 2008 6:57 PM
044SR
Hodgson
Steve,
Chris
Chris
Kimball
044SR
Hodgson
Steve,
Chris
since I amSteve,
Steve
Moose/SR #99
Dionne, Jacques
Chris,
Would you please include me in your e-mail as well please. Thanks!
Jacques Dionne
283SR
Chris Hodgson
Sent: Wednesday, March 12, 2008 11:46 AM
Thanks Mike,
Chris
Kimball
needed to
upload
044SR
Chris
Hodgson
Steve,
know
fuel
off,
bought
than
off.
give
cabin
system.
Chris
Jacques Dionne
283SR
Chris Hodgson
Thanks Mike,
Chris
Kimball
needed to
upload
044SR
Chris
Hodgson
Steve,
know
fuel
off,
bought
than
off.
give
cabin
system.
Chris
since I amSteve,
Steve
Moose/SR #99
