Hi craig It looks like he might have had a very hard landing normally theI just uploaded two photos in the rebel float section of the files. This is
a rebel on amphibs that's currently for sale here in Alaska. One photo is
obvious damage above the attach point and the builder's or someone's fix
(all four attach points are like this). Is this the corner wrap flex/damage
I've been reading about in our forum? What do you think was or wasn't done
during the build?
The other photo is of the tail section; the fin and rudder are obviously not
of rebel descent although I can't tell what it might have come from. The
owner flew it up from Fl last summer and left it on consignment. He was
asking 77,000 but now it's down to 72,000, I think. It looks a little rough
and I'm pretty sure both tanks are leaking.
rear attach points punch in right at the corner not up the side like that.
I'd be really concerned if the front attach points show damage because
that's also the main carry through for the wings. It looks to me like the
fin and rudder are rebel parts but he made a different rudder tip. What
does seem weird in the tail picture is that the elevators aren't even with
the tips and they don't come back as far as the rudder. Maybe he shortened
the cord on the stabilizer because from the picture angle it looks like the
stabilizer struts are swept forward instead of being straight. I also see
that he split the flaps and ailerons which is generally felt to be an
undesirable mod. It's probably repairable for not a huge investment in
parts but the value of the plane really depends on te condition of the
engine and what avionics are installed. If you could put up a couple more
pictures of the tail from different angles and close ups of the front and
rear attach points it would help.
