[rebel-builders] fiber vs. metal lock nuts
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 7:11 pm
Hi Ron, that was one of the things that I had to change for my inspector. I
had to use metal locking nuts any where around the muffler or muffler
brackets. Any where that heat might damage the fiber nut.
Jim 333
On 12/11/2007 1:38 PM, "Ronald Shannon" <rshannon@cruzcom.com> wrote:
Assuming equal or better strength, is there any application where a metal
self-locking nut (ex. MS21042) should not be used instead of a fiber nut?
The MS21042's have a smaller wrench bearing area, but are lighter. It has
been suggested the metal grip may be harder on bolt threads, affecting bolt
re-use, but other than those that...what advantage does a fiber nut have
over a metal self-locking nut, if any?
Post by Wayne G. O'Shea » Sun Feb 19, 2012 7:11 pm
Yes Metal nuts only firewall forward. I think what Ron is asking thou... can
he use metal nuts everywhere else to save some weight and the answer is
yes...but you're right Ron.. they are a little harder on hardware that you
plan to disassemble and reassemble.
Sent: Tuesday, December 11, 2007 3:42 PM
Subject: Re: [rebel-builders] fiber vs. metal lock nuts
Jim 333
bolt
Ronald Shannon
Post by Ronald Shannon » Sun Feb 19, 2012 7:11 pm
Thanks guys. As I thought. I wouldn't use fiber nuts in the FWF and, due to
weight, prefer not to use them anywhere. However, MAM specifies them all
over the place aft the FW. Perhaps the metal stop nuts weren't common when
the manual was written or something.
BTW --I think it bears repeating -- I've been using Click Bond nutplates in
all not-too-hot places I can (torque tube ends, stabilizer forward attach,
etc.) They're super -- only one hole needed instead of three and a lot less
work than riveted nuplates. Sometimes they're in short supply though. From
the Interesting Rumor Dept.: a reliable source mentioned Click Bond is
(supposed to be) supplying parts to the 787 but is one of the suppliers with
their own production problems, contributing to delays on the 787.
can
inspector.
Jim 333
Post by Drew Dalgleish » Sun Feb 19, 2012 7:11 pm
Fibre lock nuts have been the industry standard for many years so it's hard
to blame MAM for specifying them. I don't think that the metal ones would
cause any harm but if you're doing it just to save weight I think emptying
your pocket change before flying would save a lot more. Is there any price
difference? Even a penny a nut would add up to a lot of money for MAM.
Michael Kraus
Post by Michael Kraus » Sun Feb 19, 2012 7:11 pm
FYI - Van's uses fiber lock nuts exclusively in all their kits too. I would have to believe it was for cost reasons.
For me, every critical item gets all metal nuts (control rod bolts, flap/aileron attachments, etc) and other non-critical items get the fiber nuts. Of course FWF is almost exclusively all metal nuts.
-Mike Kraus
RV-4 flying
RV-10 electrical
SR289 boxed awaiting assembly....
Sent: 12/11/07 6:09 PM
Rick Muller
Post by Rick Muller » Sun Feb 19, 2012 7:17 pm
I think the only place that metal ones are suggested are in high temp areas
where the fiber would melt, i.e. engine compartment.
Rick Muller
SR70
-Mike Kraus
RV-4 flying
RV-10 electrical
when
hard
emptying
Rick Muller
Rick.H.Muller@gmail.com
303 641 6623
