[rebel-builders] Fuel Leak
Richard Wampach
Post by Richard Wampach » Sun Feb 19, 2012 6:57 pm
Any one familiar with fuel leaks? (SR-3500 60 gal tanks)
Two weeks ago I did the re-seal job on my left wing, added the 6 Murphy
provided access holes, (plates still off), and have waited for a
positive cure of the 890-2 sealant. I got brave this morning and added
6 gallons of av gas. As soon as I rotated the wing nose down a drip
started.
It is located at the front of the #5 may on the bottom just in front of
the filler cap. It seeps out from under the doubler plate at the lift
strut fitting aft inboard corner. Only have about 2-3" of fuel against
the front spar. No other leakage.
Has any one else had a leak at location?
Dick Wampach SR-108
Post by Drew Dalgleish » Sun Feb 19, 2012 6:57 pm
started.
Dick Wampach SR-108
Are they philipine built wings with solid rivets? If so I'd suspect poor
surface preparation before assembly. If they're pulled rivets probably one
of them cracked while being pulled. On my floats I had about a dozen rivets
below the waterline that leaked. The solution for that is to figure out
which rivet, drill it out and replace it.
Richard Wampach
Subject: RE: [rebel-builders] Fuel Leak
Yes they were made in the Philippine. Murphy said many had leaked from
that facility and sent me the kit of new inspection plates and 2 quarts
of sealant which I have kept in the refrigerator, and did mix and flow
very well.
I suppose it will just take another heavy glob in that area. It does
have a "U" shaped angle at about 1" from the bottom of the tank, on the
spar, at which the bottom bolt to the lift strut fitting goes through in
the next bay outboard--this is in the dry portion of that short bay.
Dick
Are they Philippine built wings with solid rivets? If so I'd suspect
poor surface preparation before assembly. If they're pulled rivets
probably one of them cracked while being pulled. On my floats I had
about a dozen rivets below the waterline that leaked. The solution for
that is to figure out which rivet, drill it out and replace it.
started.
against
Dick Wampach SR-108
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 6:57 pm
Dick,
Brent Blue had fuel leaks which he was able to successfully seal using the
method described below:
Ted:
"You can use a shop vac at low power and seal the hose up with duct tape to
the fueling port. Not very eloquent but works. You don't want to put too
much vacuum on the tank due to worries about collapsing it so leaking is OK.
All you want is enough vacuum to suck in the honey consistency proseal. The
ideal look would be for there to be some "mushroomed" proseal sucked though
the leak, some in the leak it self, and some on the out side. Then, turn
off the vacuum, wait 24 hours, and test. Last time I did it, it worked
great.
www.sealpakcoinc.com has it. I just ordered it from them and it is in
stock.
I think the honey one I ordered is the CS3201A. The women who took the
order is very knowledgeable so she will steer you correctly. You might also
want to order some CS 3330B. It is the tank door sealant so if you ever
have to get the inspection doors off, you don't need to destroy the door to
do it. Still has the same properties but not as stiff.
I order the stuff in the cartridge. You do not need a special gun to use it
but is self mixes this way so it is neater. A bit more expensive but as I
told Steve Culp, I am way pass the point of penny pinching!"
Richard Wampach
Sent: Thursday, October 04, 2007 2:58 PM
started.
Dick Wampach SR-108
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 9:23 pm
I would go with Proseal diluted with 50/50 solution. It is a heck of a
job to de-rivet. What I did was cut a hole into the rib next to the
wing, made a cover along with two doublers to cover the hole, then
poured the diluted Proseal mixture near the rear spar in each section
and tilted the upside down wing at an angle so that te Proseal would
run down to the trailing edge where the spar and skin come to gather
while alternating lifting the wing tip and the fuselage end of the wing
to ensure an even flow. I then Prosealed both doublers and riveted
them in place, then Prosealed around the cover plate and riveted it
in place. No leaks from the top trailing edge or the access plate
that I riveted in. However, after about 2 weeks of flying the top
outside edge near the filler cap started to weep (gradually seep out
over a 24/48 hour period). I mention this as one might put the diluted
Proseal all around the top edge of the tank.
Good luck
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Alan
Hepburn
Sent: Wednesday, May 26, 2010 7:03 PM
Subject: [rebel-builders] Fuel Leak
Well, I just got back from playing ring around the volcano on a
Transatlantic trip. Delivered four airplanes (not Murphies) safely to Paris
on schedule. So no I'm trying to figure whether to slosh my leaky tank with
Proseal diluted with 50:50 toluene/MEK, or de-rivet the rear lower skin at
the TE and try to localize the leak. What would you do?
Al
G. O'Shea
Sent: Wednesday, May 26, 2010 5:27 PM
Subject: Re: [rebel-builders] Rebel / Elite - Dipstick clearance on
Dynafocal mounts
Hey Al !!! Where the hell ya been??? ;O)
Sent: Wednesday, May 26, 2010 4:46 PM
Subject: RE: [rebel-builders] Rebel / Elite - Dipstick clearance on
Dynafocal mounts
My mount was wrong and Murphy replaced it - but that's about 5 years ago.
Al Hepburn
G. O'Shea
Sent: Tuesday, March 23, 2010 11:45 PM
Subject: [rebel-builders] Rebel / Elite - Dipstick clearance on Dynafocal
mounts
Someone asked if it was a common issue that his dipstick tube was hitting
the mount a while back....
.. .. so while bolting up the latest (O-320-E2D) engine installation
today,
I took a picture after everything was tightened up.
This has been the typical clearance on every Dynafocal engine I've mounted
to a Murphy made mount. About 3/16 to 1/4"....so not sure why the fella
had/has issues.
http://www.irishfield.on.ca/gallery/dip ... omount.jpg
Post by Wayne G. O'Shea » Sun Feb 19, 2012 9:23 pm
I hate to be the bearer of bad news... but if you didn't scuff and scrub the
heck out of the area to get proper adhesion, you'll be in there again!
Al, I'd either make inspection holes in all the 3/4 bays behind the rear
bulkheads of the tank.. or the easiest with the "newer" style tanks with the
skin riveted to the oversized tank skin outside the tank, like you said just
drill them out and cut the skin off at the outboard fuel tank rib.... as you
can't get it out of the way otherwise. Leave the cut about an inch inboard
of the last rib.. so when you replace you can make the new piece about 2"
longer than removed to do a triple rivet row to join things back together
and return the skin strength.
Before you do that though....Are you sure it's leaking at the rear??? I find
the majority of leaks end up being stringer holes.. where the proseal didn't
get inside the "J" and or slumped away leaving a pin hole. Drain the tank
and let it air out while you are removing the wing tip. CAREFULLY put a 100W
chandeler bulb into the filler neck and turn on. Look down all the
stringers for a light beam.
Sent: Wednesday, May 26, 2010 7:30 PM
Good luck
Hepburn
Paris
with
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
Al Hepburn
G. O'Shea
mounts
today,
mounted
had/has issues.
Alan Hepburn
Post by Alan Hepburn » Sun Feb 19, 2012 9:23 pm
Thanks for this. I have no visible leaks, so I figure it must be somewhere
on the rear bulkheads. I had thought about putting an access plate in the
root rib as you describe, but I'm wondering why you wouldn't just stand the
wing trailing edge down and pour about a pint of diluted Proseal through a
tube towards the rear bulkheads, then move the tip up and down and the
leading edge backwards and forwards. Then pump off the excess Proseal and
ventilate it to evapourate the excess solvent. I'd also planned to use some
gentle pressure to try to force the stuff into the leak. How long did it
take the Proseal to cure? Did you use the same 50:50 toluene:MEK mix, and
how thin did you make the sealant? I'm thinking about like engine oil. I'm
told you should rinse the tank thoroughly with MEK first.
This leak appeared after about 4 years in service. I've tried looking for it
with a flexible inspection camera through one of the flap hinge access
covers, but can't be sure of having seen the source.
Al Hepburn
Gustafson
Sent: Wednesday, May 26, 2010 7:31 PM
Good luck
Hepburn
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
Al Hepburn
G. O'Shea
mounts
today,
had/has issues.
Alan Hepburn
Wayne, this has got to be a pretty small leak. It just emerges when the
tank is full and has been sitting for several days. The tank has been empty
and ventilated all winter, so I think all the fuel vapour is long gone. so
now I have one vote for sloshing with Proseal, and one for opening it up and
looking for the source. I have inspected the outboard rib area pretty
thoroughly with a snake camera, and can see no sign of 100LL blue stains. I
was thinking of filling the thing with water died with magenta printer ink
to see if I could locate the leak that way. Then I'd rinse it out with
methyl alcohol to dry it out.
Al
G. O'Shea
Sent: Wednesday, May 26, 2010 8:16 PM
Subject: Re: [rebel-builders] Fuel Leak
Good luck
Hepburn
Paris
with
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
Al Hepburn
G. O'Shea
mounts
today,
mounted
had/has issues.
Just drill the rivets out of the rear spar/lower skin junction and the first
flange of the root rib and next rib or two if required. That should allow
you enough of a view to find a suspect stain and to retrieve the rivet shop
ends. Then proceed accordingly!
Sent: Wednesday, May 26, 2010 9:03 PM
empty
so
Al
G. O'Shea
just
you
find
didn't
100W
Good luck
Alan
Hepburn
Paris
with
at
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
ago.
Al Hepburn
G. O'Shea
Dynafocal
mounts
hitting
today,
mounted
had/has issues.
Gary Gustafson
I did use a 50/50 mixture of toluene and MEK. I did slosh MEK inside
first and let it dry for several days. The Proseal/MEK/toluene mixture
was a bit thicker than engine oil but not by much. It flowed slowly. I
used a small cup on a rod to transport a bit of the mixture to each
section and had the wing tilted so that when I poured the mixture would
land just above the rear J panel. Once I sealed the opening in the rib
next to the fuselage, I applied 4 PSI to the inside of the tank (measured
with a water menometer for about 5 hours. I do not know how long it
will last as I did not scuff up the areas where the leak(s) were
occurring.
However, I would listen to Wayne as he has had much more experience than
my one patch. Mine did not leak much and I could see no light from the
outside when a small LED flashlight was inserted on a rod. My wing tanks
passed the pressure test (glove inflated for 24 hours) but have now
developed weeping leaks that take a day to notice. I have noticed that
the doors initially opened and closed easily and now stick or are hard
to close. Which leads me to wondering if the plane 'settles' or moves
slightly as it is broken in. The other thing is that I wonder if the
leaks in the tanks could have developed via thermal expansion and
contraction here in the hot Florida sun.
Hepburn
Sent: Wednesday, May 26, 2010 8:58 PM
Al Hepburn
Gustafson
Good luck
Hepburn
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
Al Hepburn
G. O'Shea
mounts
today,
had/has issues.
Alan Hepburn
Wayne/Gary:
Before I got into major surgery, I decided to get an idea of the size of
this leak, so I'd know how long to test it before I decided it was fixed. I
put a balloon on the inlet, blew it up as hard as I could with lung power,
and let it sit. It's been there for four hours with no visible change in
the balloon, so we're not talking about a big leak - certainly nothing light
would shine through.
Now, thinking about it, the only time I noted the leak was when the airplane
was in the hangar over the winter. The tank was full. So perhaps (a) the
leak is at the top of the tank, and (b) it's so small that in warm weather
the gas evaporates before it becomes visible. It's even possible that the
leak has always been there, but is small enough that the balloon test does
not detect it over 24 hours.
So I'm starting to re-think this thing. My idea is to operate the airplane
over the summer as is. The season is short enough, for sure. I'll use the
time to try to characterise the leak. I'll start by filling the tank half
way, and see if there's any sign of a leak. I'll then add gas in 5 gallon
steps, and see if and when the leak shows up. If it is near the top of the
tank, I may even live with it, by only filling the tank immediately before a
flight, and running off the leaky side for the first hour.
At the end of the season, I can take the wing off and work on it over the
winter in a heated area, if I decide that it's troublesome enough to be
worth the bother.
Does this make sense?
Al
Gustafson
Sent: Thursday, May 27, 2010 4:26 PM
occurring.
Hepburn
Al Hepburn
Gustafson
Good luck
Hepburn
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
Al Hepburn
G. O'Shea
mounts
today,
had/has issues.
Yes it does Al. I 've seen many tanks that are great until totally full.
That is usually the upper forward stringer leaking. With you on amphibs you
sit pretty level.. so you get almost 1/2 tank or so before the fuel is up to
the top of the rear tank bulkhead. If it leaches when you start leaving it
at about 3/4 tank, I would suspect a leak thru one of the rib flange to rear
bulkhead areas (at the top of course). Always find it seems to be an easy
spot to miss getting enough gooo into when building and have fixed a fair
number of those. That one is easily fixed by what I described yesterday by
pulling he lower skin out of the way to work. Scuff 'till the cows come home
around ALL the ribs/skins/bulkhead out at least an inch onto every surface
and then spread PRC/Proseal/Sealpack onto the COMPLETE perimeter to build a
dam. Saves tearing into the inside of the tank for weepers.
Remember when you are blowing up tanks to check for leaks.... You put enough
PSI in there to blow up the balloon and it stays there for a few hours. Next
time grab a condom.. less prone to any air escaping thru the pores and the
lubricant helps with the seal on the filler neck (you need to retain with an
elastic before inflating). Blow it up to look like a water tower and leave
it for a couple DAYS. Temperature and barometric changes should make it
disappear into the tank on a cool morning and then blow back up through the
day. You know you have a perfect tank when it actually creates enough vacuum
to inflate that condom inside the tank! I use a well pressure tank snifter
valve (ie like a valve stem) threaded into one port with the others plugged
or the outlet valve shut off. Then I just fill it with the air compressor
until that condom looks like a fancy water tower!
Sent: Thursday, May 27, 2010 5:15 PM
Wayne/Gary:
light
airplane
airplane
worth the bother.
Al
Gustafson
occurring.
Hepburn
somewhere
some
I'm
it
Al Hepburn
Gustafson
Good luck
Hepburn
Paris
with
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
Al Hepburn
G. O'Shea
mounts
today,
mounted
had/has issues.
Alan Hepburn
At 66, I didn't have the nerve to ask the girl in the store where they keep
these!
G. O'Shea
Sent: Thursday, May 27, 2010 5:43 PM
Wayne/Gary:
light
airplane
airplane
worth the bother.
Al
Gustafson
occurring.
Hepburn
somewhere
some
I'm
it
Al Hepburn
Gustafson
Good luck
Hepburn
Paris
with
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
Al Hepburn
G. O'Shea
mounts
today,
mounted
had/has issues.
Post by Walter Klatt » Sun Feb 19, 2012 9:23 pm
The other place it might leak out of, if you used the standard 1410 rivets,
is through the rivet mandrels. I had a couple weeping on me shortly after it
was new, and it was on the top of the tank near the rear, and only when
filled right to the top with fuel, sitting in my hangar for a few days. I
used a small dab of Seal-all on the outside each rivet head that had weeping
(about 3 or 4) and has been good for the last 10 years.
Hepburn
Sent: Thursday, May 27, 2010 2:50 PM
these!
G. O'Shea
Wayne/Gary:
light
airplane
airplane
worth the bother.
Al
Gustafson
occurring.
Hepburn
somewhere
some
I'm
it
Al Hepburn
Gustafson
Good luck
Hepburn
Paris
with
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
Al Hepburn
G. O'Shea
mounts
today,
mounted
had/has issues.
LOL Al... you should have been a mouse on the wall when I sent my shop
assistant (male - boyfriend of my youngest sister-in-law) a few years
back... over to my older sister-in-law's convenience store to ask if she had
any condoms!!
Sent: Thursday, May 27, 2010 5:50 PM
keep
these!
G. O'Shea
you
rear
home
enough
Next
an
vacuum
plugged
Wayne/Gary:
power,
light
airplane
weather
does
airplane
half
gallon
before
worth the bother.
Al
Gary
Gustafson
occurring.
Alan
Hepburn
somewhere
some
I'm
it
Al Hepburn
Gary
Gustafson
Good luck
Alan
Hepburn
Paris
with
at
Al
G. O'Shea
Dynafocal mounts
Dynafocal mounts
ago.
Al Hepburn
G. O'Shea
Dynafocal
mounts
hitting
today,
mounted
had/has issues.
