[rebel-builders] Sealing side windows
Post by Ken » Sun Feb 19, 2012 3:11 pm
I just used butyl strip caulk Ted. Very easy to remove and lesss messy
than sticky caulks.
Ted Waltman wrote:
What compound are folks using to seal the side windows with when riveting
them in place? I thought about putting a small bead of proseal all around,
but am worried that proseal might have some adverse reaction with
plexiglass.
Thanks for input,
Ted
Rick Muller
Post by Rick Muller » Sun Feb 19, 2012 3:12 pm
I used something from Home Depot. You need to be sure it isn't acidic acid
based, for that will eat aluminum. Most of the water based caulk's are not
and recommended for use with aluminum siding that has the same problem.
Rick Muller
(303) 664 9219 Home
(303) 641 6623 Cell
rickhm@comcast.net
Waltman
Sent: Monday, June 18, 2007 5:25 AM
Subject: [rebel-builders] Sealing side windows
plexiglass.
Thanks for input,
Ted
Post by Bob Patterson » Sun Feb 19, 2012 3:12 pm
Hi Ted !
The windshield manufacturers recommend Bostick 1100 -
it comes in caulking tubes from lumber supply places, in
several colours. It's very low tack, so easy to remove.
"Plexiglass" ??? Most use Lexan for side windows -
if you are using real plexi, be sure to drill holes oversize,
use large washers on rivets, and perhaps use ordinary
"pop" rivets, as they don't expand like Avex rivets ...
and pull gently ! Better yet, DON'T drill holes - make
up an aluminum frame to let the plexi float, like the
beautifully joggled skylight retainers....
http://www.prosumers.ca
plexiglass.
Thanks for input,
Ted
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 3:12 pm
Sorry, my mistake. Std Murphy "windows" that are probably out of Lexan.
Glass, lexan, plexiglass, saran wrap...all looks the same to me <grin>.
Patterson
Sent: Monday, June 18, 2007 9:09 AM
Subject: Re: [rebel-builders] Sealing side windows
Hi Ted !
around,
plexiglass.
Thanks for input,
Ted
