a repaint job. I am pleased to not have to take it apart again for
painting and quite happy with the results. Expect most of a kilobuck
just for paint cost though and another kilobuck if you need to purchase
a good hvlp system and breathing air. You do need fresh breathing air if
you use urethane paint because no filter mask will protect you from
iso-cyanates. Biggest issue is probably whether you have a place to do
it. Usually you want to topcoat within 24 hours or so of priming so time
can also be an issue although the paint that I used allowed up to 7 days.
That princess unit is a plastic gun. I'd guess that it would likely be
fine for small jobs - not sure about a wing or fuselage?? You want to
be able to get all the way around a wing or fuselage while the first
applied paint is still fairly wet. You'd know if the unit was adequate
by the time you did the tail feathers. The Princess unit is 4 psi with
only a 15 foot hose. I used 100 feet of hose to help cool the air. The
hobby air units come with 50 feet I think to at least make sure the
intake is outside and upwind.
pequeajim@dcsol.com wrote:
I am curious how many of you guys have painted your own aircraft? I mean
if we are not going to get too elaborate, and have some quality guidance, it
would be a great way to save quite a bit of money?
On 8/21/2006 9:04 AM, bhewlett@sasktel.net wrote to rebel-builders:
-> Good Morning,
-> I see that Princess Auto has a HVLP sprayer package on sale this week for
$ 99.00
-> Includes the turbine and spray gun and 15' of hose.
-> My question is, does anyone have experience with these units. Specs
match the units from Hobby Air
-> but price is considerably cheaper. It is Power Fist brand so longevity is
questionable but if it works......
-> Thanks,
-> Brad (R195)
-> Brad Hewlett
-> Saskatoon, SK
-> bhewlett@sasktel.net
