I am working on the cage assembly. I was thinking of installing 5/16 anchor
nuts in the aft carrythrough to alleviate the need for inspection holes to
be able to remove the wishbone for float installation. You would just remove
the bolts through holes in the front carrythrough.
Has anyone tried this, or can anyone think of why it might not be a good
idea?
wishbone bolts
rognal
wishbone bolts
Hi Jesse,
You mention making holes in the front carrythrough. Just want to make you
aware that in my builder's manual it specifically states " Do not drill any
holes in the front FUS-5". In my manual this is section 12.9 paragraph 16.
My understanding from this (and conversation w/MAM Tech) is that you
shouldn't make any holes in the front wall of the forward FUS-5 tube. I
don't know why.
Just FYI.
On 6/24/2006 6:25 PM, jessejenks@hotmail.com wrote to rebel-builders:
-> I am working on the cage assembly. I was thinking of installing 5/16 anchor
-> nuts in the aft carrythrough to alleviate the need for inspection holes to
-> be able to remove the wishbone for float installation. You would just
remove
-> the bolts through holes in the front carrythrough.
-> Has anyone tried this, or can anyone think of why it might not be a good
-> idea?
-> Thanks
-> Jesse
don't know why.
Just FYI.
remove
-> idea?
-> Thanks
-> Jesse
