Rebel/Elite Float Hydraulic Reservoir Size
Terry Dazey
Post by Terry Dazey » Sun Feb 19, 2012 1:38 pm
Hello Amphib Float Builders/Flyers:
I am thinking of fabricating an aluminum float pump hydraulic reservoir
that will bolt to the aft end of an extended length float pump base.
Looking from the top, it will have a racetrack shape similar to the
shape of a pint can of solvent. The MAM plastic windshield washer
reservoir looked a bit large to me.
My question is: what is the optimum (smallest) capacity for this amphib
float landing gear reservoir unit. A pint? A quart? Or?
If anyone that has done this, do you have parts numbers for the quick
disconnect fittings, threaded inserts etc.
Suggestions? Comments?
Thanks in advance.
Terry Dazey
Rebel 662
Lake Tapps, WA U.S.A.
