[rebel-builders] Elite Elevator Travel
Post by Wayne G. O'Shea » Sun Feb 19, 2012 1:27 pm
U need to listen to Al Hepburn here Roy...not me! :O)
The Elite we have here the customer wants to fly first and do the mods later
if he feels the need!
Sent: Tuesday, February 28, 2006 1:15 PM
Subject: Re: [rebel-builders] Elite Elevator Travel
Wayne---Just starting stab on Elite---what mods did you do to soften pitch
and how much would you add to stab angle to do away with added trim----Roy
Pinner--- Elite #799 thanks
-------Original Message-------
Date: 02/27/06 19:40:28
Wayne et al:
To get the travel I quoted, I need to push the stick a good 2 1/2" forward
of the panel, WITH THE WAY I'VE RIGGED THE STICK. Now, the amount of up
elevator you get in practice depends not just on the rear stop position,
but
on the seat position, the size of your gut and certain other appendages.
My
legs are fairly long (35 1/2" inside seam, won't boast about the other
appendages), so if anything I've assumed the seat might further back than
your average pilot might, though I didn't size it for yours truly only.
Everything then went from that "maximum acceptabe rearward travel" point,
not the maximum geometrically possible. Of course, that point is rather
subjective. As for forward travel, spin recovery is the key position that
you're going to hold for any length of time, but if you stall the airplane
momentarily, you might well want a quick pulse of down, and 12 degrees
just
looks like that's getting kind of marginal. Also, when you measure that
12
degrees, am I right in thinking that's with the stick hard against the
panel? What about switches etc. in the entire arc covered by the top of
stick? And what about the thickness of the grip, your fingers, gloves,
etc., plus an allowance for you not wanting to mash said fingers against
said switches? I bet you're closer to -5 degrees.
Now, my airplane on floats flies around with a fair bit of up elevator,
particularly at approach speed, so in fact I effectively have more down
avalable than -15, though I have re-rigged the stab to try to reduce this
(didn't think to check it when I flew home from the paint shop - too
darned
cold). I guess it just boils down to how much you feel comfortable with.
You're sure as hell not going to get the -25 called for in the
instructions.
And I'm not about to spin test the thing on amphibs to tell you how much
is
enough!
Cutting the stick is not a big deal, though I must admit I'd rather have
it
a bit longer in cruise. You tend to fly with your wrist on your knee and
just grip the stick at the top with a couple of fingers. I'd rather have
the stick about 3" above knee level. But fears about over-sensitivity are
not justified, at least with the modified elevator. As I said, if I was
doing it again, I'd put in an amplifier bellcrank somewhere in the system
and live with even more sensitivity to get the nicer feel of a longer
stick.
You can lengthen the horns on the control column a little without touching
the floor, and if you raise the pivot brackets, you could do so even more.
That might be enough. But if you do that, you'll have to do some welding
on
the colum to beef up the longer horns. So, yah pays yer money and yah
takes
yer choice. The only thing I think that has the potential to really bite
you is too little down or up elevator.
Al
Unsubscrbe: rebel-builders-unsubscribe@dcsol.com
Alan Hepburn
Post by Alan Hepburn » Sun Feb 19, 2012 1:27 pm
Roy:
Not sure what you mean by "soften the pitch". Anyway, you have all the mods
I'm aware of.
I am starting with an .062" shim under the rear attach brackets, and will
report on how much effect that has. Unfortunately, on the one flight I did
with the shim in place, I did not check how effective it was. I can say
that it was not too much.
Al
Jeffrey Steenson
Post by Jeffrey Steenson » Sun Feb 19, 2012 1:27 pm
Dear Bob and Mike,
Thank you for your contributions to this discussion. I'll certainly squeeze
out every quarter-inch of forward real estate!
The only times I can recall using so much down elevator and full aileron is
in a steep slip. Ailerons always come to neutral in a spin recovery, right?
Jeffrey
Sent: Monday, February 27, 2006 8:29 PM
Hi Jeffrey !
I can tell you for sure that you don't need ANY forward stick to
recover from a stall on amphibs, or wheels, with the Elite !
Just relax, to a bit aft of neutral, and you'll be flying again easily....
Ditto for spins on wheels - - don't know about amphibs, and not toooo
anxious to try !
Might be worth re-bending your pax stick to get back that 3/4" -
might just be enough to give you the 15 degrees negative !
On Monday 27 February 2006 09:46 pm, Jeffrey Steenson wrote:
Dear Wayne and Al,
For sure I can pull it all the way back to the stops, and I can really
get 12 degrees forward. I noticed that my control sticks aren't
perfectly symmetrical, and the pax stick hits the panel when there is
still 3/4" on the pilot's side. I did write to MAM today to ask about
elevator travel, and if I get a reply, it will be interesting to compare
with what they told Al.
I appreciate the advice! How about a few stalls on the amphibs, just to
see what is needed?!
Jeffrey
Sent: Monday, February 27, 2006 6:09 PM
Thanks Al. I was just curious why you'd stated Jeffrey's wasn't good
enough
missing 3 degrees down elevator compared to yours and he has the stock
stick
set up still. I'm assuming Jeffrey has sat in there to see if he can
bring it all the way back...but if you met Jeffrey you'd know he'll be
sitting a WAY back from where most of us do.
Sent: Monday, February 27, 2006 7:37 PM
but
My
just
12
darned
instructions.
is
it
stick.
on
takes
