Your following message has been delivered to the 188 members of
the list murphy-rebel@dcsol.com at 12:17:49 on 3 Feb 2001.
It's not "my" list, but I'm sure Mike will take care of your request for
you, RIGHT MIKE!
Sent: Saturday, February 03, 2001 11:28 AM
Subject: Re: fuel lines
someoneMr Wayne O'Shea,
I have been getting about ten emails a day from this Murphy Rebel Builders
List, and I don't even know how my email got added to the list. I am not
building anything. Do you know how to take me off the list, can you do
that? If not, would it be possible for you to forward this email to
youwho can take me off the list? I'd really appreciate.
Thank you sir,
Rob Kosciusko
My email is robkoz@alum.mit.edu
or robkoz@worldnet.att.net.
I don't know which one of these is on your list.
Sent: Thursday, February 01, 2001 10:04 PM
highRick, DO NOT run the fuel lines forward and then down (unless you are
running an electric fuel pump)!!!! When low on fuel, with the A/C at acarb,angle of attack, the fuel is being supplied by "siphon" action to theas there is no longer any "head" pressure available from the tank. If
siphonhappen to drop a wing (especially if only running on one tank) the
youwill be broken (as the fuel goes away from the inlet) and most likely
manual,you'rewill be unable to get the siphon going again. The engine will run for a
short while, until the carb bowl and immediate line goes empty, thena GLIDER! If you run the lines back and then down as shown in the
steepthe only way you will have fuel problems will be if you hold a VERY
sidedive for a VERY long time, or if you run the tanks dry!
Just my 2 cents, but of course it is your Rebel, so the choice is ALWAYS
yours!!
To: "Rebel Builders" <murphy-rebel@dcsol.com>
Sent: Thursday, February 01, 2001 9:15 PM
Subject: fuel lines
Hello everyone,
I need some comments on my approach to my proposed fuel line
routing. My plan is to run the main lines along the outside bottom of
the fuselage root ribs (FUS-27 L&R) and then either down the side (the
narrow side facing the center of the A/C) or down the back(the wide
thisfacing the rear of the A/C) of the front door post uprights(FUS-4). I
could also run the first portion inside along the bottom of the root
ribs and jump inside and down the door post. When the line gets to the
main square tubes it will run downhill to the center of the A/C. At
teflonpoint I will tee the two lines (one from each side) together and also
have a sump drain there. Now one line will run up to the firewall and
gascolator. These lines could be enclosed in a cover arrangement to
avoid damage. Stainless steel line is also an option for these. One
other possibility for line material (5/16" i.d.) is high pressure
hose.Availablehose that is enclosed in a braided stainless steel jacket. The braided
hose assemblies are about $30.00 each for a six foot long
*---------------------------------------------------------------------------from McMacter-Carr. These hoses are typically used for oil pressure
lines and other high pressure applications.
Feel free to bombard me will all of your comments.
Rick D.
*-----------------------------------------------------------------------------------*Contributors' page at:
Visit the book store at:
*---------------------------------------------------------------------------Contributors' page at:
