Scale for measuring Pro-seal
Keith Leitch
What do most of you guys use when weighing out the
pro-seal for mixing. Where to purchase a reasonable
scale I guess is the question.
Keith
Do You Yahoo!?
http://mail.yahoo.com
Keith
Do You Yahoo!?
0 to 300 gram digital scale. Cut a piece of scrap .020 throw it on the scale
and hit tare to zero. Then mix 10 to 1 by weight.
To: "Murphy Rebel Builders" <rebel-builders@dcsol.com>
Sent: Monday, January 30, 2006 6:14 PM
Subject: Scale for measuring Pro-seal
Keith
Do You Yahoo!?
Although I agree with seeking an accurate measurement the Aircraft Mechanic
(IA) at the local FBO told me that she just eyeballs it and has never had
any trouble. Assuming this is true it would appear that ProSeal has a fair
tolerance for a less than perfect mix. I'm sure you would never get a
ProSeal rep to admit that.
Mike K.
G. O'Shea
Sent: Monday, January 30, 2006 2:19 PM
Subject: Re: Scale for measuring Pro-seal
Mike K.
G. O'Shea
Keith
Do You Yahoo!?
Jean Poirier
I have bought a postal scale that have 2.2 kg capacity in 1 gram increments.
+/- $35.00 canadian dollars at office depot.
Jean
Rebel 747R
Jean
Rebel 747R
Keith
Do You Yahoo!?
Mike Betti
Postal scale from Wal-mart, $25, works good just like Wayne mentions. Of
course the scale looks pretty bad when your done with it but still
functionable.
Mike Betti
771E
From: "Jean Poirier" <jean.poirier@oxyportneuf.com>
Sent: Monday, January 30, 2006 5:57 PM
functionable.
Mike Betti
771E
increments.
Jean
Rebel 747R
Keith
Do You Yahoo!?
Jeff McMurrer
We just use a digital food weighing scale, can be purchased anywhere. Mixing proseal by eye to a nice grey color, that all depends on what you constitute as "grey". Proseal is supplied in a ratio mix of 100 to 10 (10 to 1), why not use it... Drying time all depends on temp and humidity, if not done properly, you may be waiting longer than you want for it to dry.
There's nothing better than having a non leaking wing. Well there may be a few things better......
Jeff
Date: Monday, January 30, 2006 3:55 pm
Subject: RE: Scale for measuring Pro-seal
Jeff
Mechanic(IA) at the local FBO told me that she just eyeballs it
and has never had
has a fair
get a
Mike K.
From: mike.davis@dcsol.com [mike.davis@dcsol.com] On Behalf Of Wayne
G. O'Shea
the scale
Keith
Do You Yahoo!?
Yah....but clean your hands before grabbing her hips.....
Sent: Monday, January 30, 2006 7:14 PM
Mixing proseal by eye to a nice grey color, that all depends on what youWe just use a digital food weighing scale, can be purchased anywhere.
a few things better......There's nothing better than having a non leaking wing. Well there may be
Jeff
and has never had
has a fair
get a
Mike K.
G. O'Shea
the scale
Keith
Do You Yahoo!?
KEITH OLIVER
I keep mine in a zip lock bag even when I am using it.
Keith B. Oliver
Betti
Sent: Monday, January 30, 2006 7:13 PM
functionable.
Mike Betti
771E
Keith B. Oliver
Betti
functionable.
Mike Betti
771E
increments.
Jean
Rebel 747R
Keith
Do You Yahoo!?
"rebel" password "builder" Subscription services located at:
List archives located at: https://www.dcsol.com/login username "rebel"
Robert and Olga Johnson
Keith: I made a simple balance beam of 10 to 1 ratio. Proseal on the long
end , Black crap on the short end. When I have an equal balance, I remove,
mix and use. Beam must obviously be balanced prior to beginning.- Bob J
Keith
IIRC there is progressive small measureable degradation of proseal as
you deviate more than 1% from the 10:1 ratio so I think it is good to
try and keep it within about 10%. I could be wrong but that's what I
seem to recall from the factory seminar at OSK?? I use a triple beam
balance because it is repeatably accurate to better than one tenth gm
for small batches - overkill perhaps but I always wanted one anyway ;)
Seriously though if the electronic scale is only accurate to 1 gm you
might as well not bother using it for small batches. When I looked at
typical small electronic scales last, they were all only accurate to 1
or often 2 gms. I mixed a number of 30 to 50 gm batches which means 3 or
5 gm of hardener. A 1 gm error is 33% of 3 gms and indeed you can
probably do as well or better by guessing! Such as scale can't guarantee
better than 10% ratio even when mixing 110 gm of product and I didn't
mix any batches that large...
Mike K.
G. O'Shea
