single pair of cylinders and interconnected pedals. This whole thread has
had me confused as to why guys are doing the added complication of dual
cylinder assemblies.
Sent: Saturday, October 22, 2005 12:32 AM
Subject: RE: Brake Master Cylinders - 2 pair
airplane."I wonder if there is enough room to install the Super Rebel system in the
Rebel. One set of brake cylinders on the pilot side and the co-pilot side
mechanically connected to the pilot side. As a flight instructor, I have
only once had a problem with a student when I said, "I've got the
He wouldn't let go when the airplane entered a spin after mucking up an
approach to landing stall. Had to jab him in the ribs. All my students
except for that one time knew that "I've got the airplane" means hands and
feet off the controls.
Gustafson
Sent: Thursday, October 20, 2005 2:10 PM
I gave up trying to figure out where to put them and how to use them,
let alone find a supplier. I assume one set of brake pads.
If they are on the output side, once the brakes are set the brakes
will stay locked.
If they are on the intake side, both pedals become slower acting, but
this has the best chance for success.
If the brakes are in series, the down stream set dominates, and the up
stream pedals are useless. This is my approach.
After asking around I was not able to find check valves.
I was able to see a Rebel that had a mechanical system but plane is in
Maine now.
Sent: Thursday, October 20, 2005 4:31 PM
Subject: Re: Brake Master Cylinders - 2 pair
Hi Jack
No I don't but out of curiosity how would you plumb them. Off the top of
my head I don't see how 4 check valves will work. Maybe on the inlets to
the cylinder if they will open under very little pressure but then it
will be difficult to bleed the system. Most guys seem to use a
mechanical system to link the brake pedals to one cylinder on the Rebel.
lawsondj@comcast.net wrote:
for student/insructor purposes. Does anyone know where to get the requiredI really would like to consider operating the brake cylinders in parallel
check valves. These valves (4 req'd) have to hold off several hundred psi.Thanks for a reply
Jack Joos, SR193
