Grant,
I have come to yet another missing bolt in the control chapter. AN5-14A, used to connect the bellcrank to the mixer arm,is called for but was not shipped with my kit. This is getting frustrating ! It wouldn't be so bad if I had a stash of aircraft hardware to grab from, but I do not, so each missing piece causes furthur delay. Again,if you could review and give instruction to shipping, it would help.
Thanks , LUKE
467R- more bolt shortages
Luke, you have sent your mail to the wrong place!
From: LUKE&BECKY <skydoc@nidlink.com (skydoc@nidlink.com)>
To: Murphy supprt <murphy-rebel@dcsol.com (murphy-rebel@dcsol.com)>
Date: Monday, March 13, 2000 1:00 AM
Subject: 467R- more bolt shortages
Grant,
Thanks , LUKE
Luke,
It WAS the wrong email address, but it raises an interesting
question - Was that AN5-14A bolt on the original packing slip ??? If
it WAS, then you should have caught the shortage when you did inventory...
If NOT, then the packing list needs to be fixed ! Was that your objective ?
------------------------------orig.-----------------------------------------
AN5-14A, used to connect the bellcrank to the mixer arm,is called for butLuke, you have sent your mail to the wrong place!
To: Murphy supprt <murphy-rebel@dcsol.com>
Grant,
http-equiv=Content-Type><!DOCTYPE HTML PUBLIC "-//W3C//DTD W3 HTML//EN">Thanks , LUKE
<HTML>
<HEAD>
<META content=text/html;charset=iso-8859-1
href="mailto:murphy-rebel@dcsol.com">murphy-rebel@dcsol.com</A>><BR><B>Date:<META content='"MSHTML 4.72.3612.1706"' name=GENERATOR>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT color=#000000 size=2>Luke, you have sent your mail to the wrong
place!</FONT></DIV>
<BLOCKQUOTE
style="BORDER-LEFT: #000000 solid 2px; MARGIN-LEFT: 5px; PADDING-LEFT: 5px">
<DIV><FONT face=Arial size=2><B>-----Original Message-----</B><BR><B>From:
</B>LUKE&BECKY <<A
href="mailto:skydoc@nidlink.com">skydoc@nidlink.com</A>><BR><B>To:
</B>Murphy supprt <<A
used</B>Monday, March 13, 2000 1:00 AM<BR><B>Subject: </B>467R- more bolt
shortages<BR><BR></DIV></FONT>
<DIV><STRONG><FONT color=#000000 face="Benguiat Bk BT"
size=2>Grant,</FONT></STRONG></DIV>
<DIV><STRONG><FONT color=#000000 face="Benguiat Bk BT" size=2> I have
shippedto connect the bellcrank to the mixer arm,is called for but was not
so badwith my kit. This is getting frustrating ! It wouldn't be
giveif I had a stash of aircraft hardware to grab from, but I do not, so each
*----------------------------------------------------*instruction to shipping, it would help. </FONT></STRONG></DIV>
<DIV><STRONG><FONT color=#000000 face="Benguiat Bk BT" size=2>Thanks ,
LUKE</FONT></STRONG></DIV></BLOCKQUOTE></BODY></HTML>
Brian Cross
Hi Luke
Just my thoughts on this. When you finally get right down to it, it is very
unlikely that the AN5-14A will be the exact size. It is better to test your
assembly with a longer bolt first and then completely test your rig first
from the torque tube right back to vertical push/pull tubes. Once you have
the throws & push pull tube coming out of the torque tube running level
WITHOUT BINDING at the ball socket assemblies, (forgot the correct name HE3M
bearings?), then order the correct bolt. Chances are it will not be a -14A.
If it is, I would be surprised.
The bolt can be changed to the proper length very easily once you are
satisifed with everything. No point on hassling MAM until you know what you
really need!
Brian
Sent: Monday, March 13, 2000 8:28 PM
Subject: Re: 467R- more bolt shortages
Luke,
te:
really need!
Brian
Luke,
Grant,
<HTML>
<HEAD>
5px"><META content='"MSHTML 4.72.3612.1706"' name=GENERATOR>
</HEAD>
place!</FONT></DIV>
<BLOCKQUOTE
Message-----</B><BR><B>From:<DIV><FONT face=Arial size=2><B>-----Original
href="mailto:murphy-rebel@dcsol.com">murphy-rebel@dcsol.com</A>><BR><B>Da</B>LUKE&BECKY <<A
te:
have</B>Monday, March 13, 2000 1:00 AM<BR><B>Subject: </B>467R- more bolt
usedcome to yet another missing bolt in the control chapter. AN5-14A,
eachif I had a stash of aircraft hardware to grab from, but I do not, so
givemissing piece causes furthur delay. Again,if you could review and
