nylon washers
Jesse Jenks
nylon washers
Post by Jesse Jenks » Sat Feb 18, 2012 1:24 pm
Where do you get the nylon washers called for in the elevator/rudder hinge?
I didn't get any with my kit. Are they an AN part, or hardware store?
Thanks.
nylon washers
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:24 pm
Jesse, did I not throw a dozen in of my thrust washers?? MAM used to have
nothing there, then bought about 2000 from me and then switched to something
inferior in my mind. Give me your mailing address again and I send you some.
Sent: Monday, April 11, 2005 11:36 AM
Subject: nylon washers
hinge?
Thanks.
Keith B. Oliver
nylon washers
Post by Keith B. Oliver » Sat Feb 18, 2012 1:24 pm
I could use some also
Would be more than happy to pay for them
Keith B. Oliver
ELITE N654ME (reserved)
Farmingdale, Maine
Sent: Monday, April 11, 2005 12:41 PM
Subject: Re: nylon washers
hinge?
Thanks.
nylon washers
Jesse bought a whole airplane kit from me and why I said I'd send him some
N/C......
As previously posted......anyone that wants them just send me $5 >CASH< and
your address and I will send you a dozen. US folks US dollars and Canadian
folks CDN dollars, as this will cover the higher postage rate to the USA.
These are only for the Rebel though TTBOMKnowledge, so Keith I'm not sure if
you need them. The washers themselves are about 2" OD with a 3/8 ID hole
that fits the hinge bushing perfectly. They are about 0.032/0.040 thick and
made of nylon 6. You will never wear them out....OEM usage was the thrust
washer for TRW seatbelts, to keep the recoil spring from wearing thru the
Polypro case.
On the Rebel they are used between the hinge brackets and the
elevator/rudder spar tubes end plugs and the rivets holding the push pull
horns on. The rudder is absolutely critical as without the washer in place
the rivets will chew their way through the lower hinge bracket thanks to
gravity.
Wayne O'Shea
1516 Alvin Williams Rd
Penetanguishene, Ontario
L9M-2C1
Sent: Monday, April 11, 2005 4:22 PM
Subject: RE: nylon washers
Keith B. Oliver
Farmingdale, Maine
something
some.
hinge?
Thanks.
nylon washers
BTW, the exact dimensions for those that may have a need, OD = 1.85". ID
hole = 0.3985" and thickness is 0.042"
Sent: Monday, April 11, 2005 7:38 PM
N/C......
if
Polypro case.
gravity.
Wayne O'Shea
L9M-2C1
Keith B. Oliver
Farmingdale, Maine
have
something
some.
hinge?
Thanks.
Jesse Jenks
nylon washers
Do they sit on top of the rivets in the horn end plug, or do you cut down
the outside diameter on that one so they go inside the rivets?
Date: Tue, 12 Apr 2005 21:48:30 -0400
some
N/C......
Canadian
USA.
sure
if
thrust
Polypro case.
pull
place
gravity.
Wayne O'Shea
L9M-2C1
Keith B. Oliver
Farmingdale, Maine
have
something
some.
hinge?
store?
nylon washers
The main idea is to keep those rivets from wearing through your hinge
bracket...so YES they get left full size to cover the rivets.
Sent: Tuesday, April 12, 2005 10:15 PM
some
N/C......
CASH<
Canadian
USA.
sure
if
hole
thick
thrust
Polypro case.
pull
place
gravity.
Wayne O'Shea
L9M-2C1
have
something
you
some.
elevator/rudder
store?
Jesse Jenks
nylon washers
I thought maybe you could use a couple to get above the rivets, but that's
easier.
Date: Tue, 12 Apr 2005 22:22:29 -0400
down
ID
him
some
CASH<
and Canadian USA. sure
if
hole
thick
and thrust
thru
the pull place
thanks
Of
have
you
elevator/rudder
store?
Nylon Washers
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:27 pm
Dale, Dave and Keith...your washers hit the mail box this morning. Let me
know when they arrive oifa@irishfield.on.ca
