O-200 engine
Jean Poirier
O-200 engine
Post by Jean Poirier » Sat Feb 18, 2012 1:20 pm
Hello!
Couple of conversation in the last few days about fuel economy and engine.... is someone flying a Rebel back of a O-200? Performance on wheels and skies? May be easiest to find at a fair price than Lycon and surely cheaper tha Rotax....
I am building the second wing now and I think I will have to choose the engine at the beginning of the fuselage building because the firewall position? What happen to those who fly firts with a smaller engine and than change for the heaviers ones?
Jean
Rebel 747R
O-200 engine
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:20 pm
Actually..if you want a 100HP in an air cooled engine find yourself an
O-235-C or C1. There are so many of these engines out there you can pick
them up now for less than what they were in 1993. I paid $6000cdn for mine
in 1993 as a good 1/3rd time running engine and sold it two years ago for
only $3750 at about 1/2 time and still running like a top. Couldn't spark
any interest at any higher price.
On the other hand O-200's are getting as rare as hens teeth, thanks to lower
production volumes to start with and formula racers blowing them up at
4000rpm's etc...so they are getting hard to find and very pricy.
Of course the other real reason to go O-235 first is..there is very little
needed to be done when you want to upgrade to an O-320 x150/160 HP as the
mount is the same, airbox fits etc etc with just an oil cooler to add to the
installation and you are flying again in a couple days. They are so close
that even the throttle and mixture throws don't need to be re-adjusted.
Jean, I flew mine with the O-235, heavy original starter and the battery
(G-25) on the firewall for many years. When I switched to the O-320 it has a
lightweight alternator and I even got lazy and left the battery on the
firewall. Little nose heavy alone and low on fuel, but still flew fine. I
just moved the battery to the rear of tailcone this fall, after installing
the hydraulics for the skis/floats entirely forward of the datum .....so
thought it was time to move the battery before going to floats in the next
month or so.
To: "rebel builder" <rebel-builders@dcsol.com>
Sent: Wednesday, March 23, 2005 8:11 AM
Subject: O-200 engine
Hello!
Jean
Rebel 747R
Jean Poirier
O-200 engine
Hello Wayne
Thanks for the quick answer. When originally build, it was for the O-235
firewall?
I know that L2C are more powerfull and parts are much cheaper than C1B for
they will be more rare too? and more expensive?..
Have you take your decision for the Sun'fun?
Jean
Sent: Wednesday, March 23, 2005 10:56 AM
Subject: Re: O-200 engine
lower
month or so.
Hello!
Jean
Rebel 747R
O-200 engine
Yes Jean built originally for O-235....but I will not move the firewall back
on a Rebel anyhow, unless the customer requests it.
L2C is higher compression/hp and dynafocal mount I believe. You could go
that route as well and then if you wanted to just swap for an O-320-E2D or
similar with dynafocal mount...or any O-320 for that matter. ATC or Leavens
can send the conical case to ECI and they will convert it to a Dynafocal.
Doubtful on attending SnF. I've got a bit too far behind on Howard's rebuild
and going to need the full month of April to get it done and flying on time.
Gotta stay off this 'puter
Sent: Wednesday, March 23, 2005 11:09 AM
Hello Wayne
O-235
firewall?
Jean
mine
for
spark
lower
little
close
has
installing
next
month or so.
Hello!
Jean
Rebel 747R
O-200 engine
Post by Bob Patterson » Sat Feb 18, 2012 1:20 pm
Hi Jean !
If you can find a real L2C (NOT an 'upgraded' one), or an N2C,
they are definitely worth the extra bucks ! Those 10 extra horses are
REAL horses - will give you at least 10 mph more cruise, and make
floats <just> possible/bearable.
Our 80 hp. 912 Rebel outperformed our O-235 Rebel in every area,
except - fully loaded on a very hot day, the climb was better with the O-235.
Otherwise, the 912 took off shorter, climbed faster, and cruised faster, on
half the fuel !! This is entirely because the O-235 weighs SOOoooo much more
than the 912 - weight is the performance secret ! :-)
Of course, going to an L2C would have changed that (ours was an old C2C),
but going to a 912-S should swing the balance back to the 912 in a big way !
I still think that's the best performance for the dollar ....
........bobp
On Wednesday 23 March 2005 11:09 am, Jean Poirier wrote:
Hello Wayne
firewall?
Jean
lower
month or so.
Hello!
Jean
Rebel 747R
O-200 engine
Post by Walter Klatt » Sat Feb 18, 2012 1:20 pm
Not that I am pushing the 0200 over the 0235 lyc, but if weight
is important, the 0200 is listed at 170 lbs dry weight while the
0235-C comes in at 213. That's quite a difference for the same
power.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Wednesday, March 23, 2005 9:33 AM
Hi Jean !
extra horses are
cruise, and make
every area,
........bobp
Hello Wayne
firewall?
Jean
lower
and very pricy.
month or so.
fuel economy and
O-200 engine
You're right Walter ! And weight IS critical !!
There IS a difference in power, though - in standard configuration,
the O-200 was something like 90 hp/100 hp for 5 minutes, whereas
even the old O-235C1 was 100/108 hp for 5 min. (all aircraft engines
of that era showed a permitted higher output fot 5 minutes max.),
and an O-235L2C will give 108/118 hp - a significant improvement.
The O-200 was the old C-85 stretched, with higher compression,
etc. to about it's max. - any extra compression has blown cylinders off.
There are ways to get more power, but reliability really drops.
There seems to be a lot more room to improve on the O-235
without sacrificing so much ....
But all of that means work, time, and money - and a bare 912
still weighs only 128 lb - and a 912-S, installed, with water & oil,
will only be about 158 lb. - still lighter, and a modern engine, with
modern metallury, and modern design .... :-)
Maybe a few dollars more will get you flying a lot sooner,
and a lot easier, given that the design is pretty much off-the-shelf !
power.
Patterson
Hi Jean !
extra horses are
cruise, and make
every area,
........bobp
Hello Wayne
firewall?
Jean
and very pricy.
fuel economy and
