wiring connectors
wiring connectors
Post by Ralph Baker » Sat Feb 18, 2012 1:02 pm
Al,
Were you able to find a Molex series with enough ampacity for the
heavier loads such as landing lights and pitot heat?
Regards, Ralph Baker
Al Paxhia
wiring connectors
Post by Al Paxhia » Sat Feb 18, 2012 1:02 pm
Ralph,
The series plug does use the larger pins, don't recall the size. Also use
50 W halogen bulbs for both landing and taxi lights with no problem (only 2
hours of night flying in over 400 hours) but the landings lights
continuously wig-wag with no problem.
I would not use them for pitot heat unless you used multiple pins, then I'm
not sure that is a good application some testing is in order first.
Al
Sent: Thursday, January 20, 2005 10:57 AM
Subject: wiring connectors
Al,
brad
wiring connectors
Post by brad » Sat Feb 18, 2012 1:02 pm
Ralph, Al
Don't know about the specific plugs you are discussing but on a general note
all manufacturers rate their plugs by max current draw and voltage.
A 50W light at 12 VDC will draw about 4.25 amps. Check with the plug
manufacturer and get their current rating for each size and type of connector.
FWIW: If you only know the Wattage the calculation is
Current(amps) = Watts/Voltage
With the proper rating information you can buy the correct size pins for what
ever you are connecting.
Brad (R195)
On 1/20/2005 12:05 PM, PAXHIA2@COMCAST.NET wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for rebel-builders@dcsol.com; Thu, 20 Jan 2005 12:05:49 -0900
-> Received: from rwcrmhc12.comcast.net ([216.148.227.85])
EHLO=rwcrmhc12.comcast.net
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 600122812; Thu, 20 Jan 2005 12:05:47 -0900
-> Received: from NEWCOMPUTER (c-24-22-142-253.client.comcast.net
[24.22.142.253])
-> by comcast.net (rwcrmhc12) with SMTP
-> id <200501202105460140013pqte>; Thu, 20 Jan 2005 21:05:46 +0000
-> Message-ID: <001e01c4ff33$d44a7180$7401a8c0@NEWCOMPUTER>
-> From: "Al Paxhia" <paxhia2@comcast.net>
-> References: <005401c4ff21$ddae2e40$ae68dad8@oemcomputer>
-> Subject: Re: wiring connectors
-> Date: Thu, 20 Jan 2005 13:05:53 -0800
-> X-Orig-MIME-Version: 1.0
-> X-Orig-Content-Type: text/plain; format=flowed; charset="iso-8859-1"; reply-
type=original
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 6.00.2900.2180
-> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2180
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> Ralph,
-> The series plug does use the larger pins, don't recall the size. Also use
-> 50 W halogen bulbs for both landing and taxi lights with no problem (only 2
-> hours of night flying in over 400 hours) but the landings lights
-> continuously wig-wag with no problem.
-> I would not use them for pitot heat unless you used multiple pins, then I'm
-> not sure that is a good application some testing is in order first.
-> Al
-> From: "Ralph Baker" <rebaker@ftc-i.net>
-> Sent: Thursday, January 20, 2005 10:57 AM
-> Subject: wiring connectors
-> > Al,
-> > Were you able to find a Molex series with enough ampacity for the
-> > heavier loads such as landing lights and pitot heat?
-> > Regards, Ralph Baker
-> > List archives located at: https://www.dcsol.com/login?mode=HTML
wiring connectors
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:02 pm
Talking with Brent at MAM today and he says Whelen was screwing him/MAM for
$16+US for a couple male plugs and two pins to finish of strobe installatons
as parts not included in install kit already bought..... so has sourced his
own replacements. Here are the prices for anyone that needs to finish off a
strobe wire end to mate up with their Whelen or Aeroflash ends (watch the
wire locations..not always the same!!!..but same plug from both mfgs). Also
has the shielded wire, but not sure where the price will be..contact him for
more information bgalye@murphyair.com Cheers, Wayne
1-480303-0 MATE-N-LOK PLUG (SAME AS WHELEN PLUG AND WHAT IS NEEDED TO FINISH
STROBES) $1.93/$1.60 CAD/US
60620-1 PIN FOR ABOVE $1.20/.99 CAD/US
1-480305-0 MATE-N-LOK CAP (FEMALE VERSION OF ABOVE) $1.93/$1.60 CAD/US
60619-1 PIN FOR ABOVE CAP Ask for price..missed in his email
Sent: Thursday, January 20, 2005 4:24 PM
Ralph, Al
note
connector.
what
Brad (R195)
[24.22.142.253])
+0000
reply-
type=original
-> X-Priority: 3
-> Ralph,
use
(only 2
I'm
-> Al
-> > Al,
Daryl C. W. O'Shea
wiring connectors
Post by Daryl C. W. O'Shea » Sat Feb 18, 2012 1:02 pm
Watch out for some series of Molex connectors (like the Mini-Fit and
Micro-Fit). They have a tendency to melt at the higher quarter of their
current rating. Dolby Labs used them in a few models of their cinema
processors and they nearly all melted while constantly passing about 80%
of their rated current. Even replacing them with a new connector they
eventually melt again, so it doesn't look like Dolby got a bad (well
worse) batch.
Never had a problem with any constantly passing less than a 75% of their
rated current.
Molex has all their product specs on their site at http://www.molex.com/
Daryl
Al Paxhia wrote:
Ralph,
Al
Al,
David Ricker
wiring connectors
Post by David Ricker » Sat Feb 18, 2012 1:02 pm
Just a note on the connector discussion, you can get these Molex parts at
digikey.com (large mail order electronics parts distributor). If you are in
Canada they even publish a Canadian price list that includes all but the taxes
(digikey.ca). The price includes brokerage which we have documented can cost an
arm and a leg.
I use them often for things I buy for my car & plane projects and prices are
very competitive. BTW, if you contact them they will send you a humungeous
catalog with plenty of interesting electronic goodies. I have picked up LED lit
switches & indoor-outdoor LCD thermometers, heat shrink tubing etc. etc.
Ralph, Al
note
connector.
what
Brad (R195)
[24.22.142.253])
+0000
reply-
type=original
-> X-Priority: 3
-> Ralph,
use
(only 2
I'm
-> Al
-> > Al,
David A. Ricker
Fall River, Nova Scotia
Canada
wiring connectors
Same deal with Newark...Canadian pricing and even a Canadian office..but
they ship from the USA via UPS and it's prepaid/brokerage done etc at no
extra costs. www.newarkinone.ca
Sent: Saturday, January 22, 2005 9:40 AM
in
taxes
cost an
arm and a leg.
are
humungeous
LED lit
for
installatons
his
off a
Also
for
FINISH
Ralph, Al
general
note
connector.
for
what
Brad (R195)
12:05:49 -0900
[24.22.142.253])
+0000
reply-
type=original
-> X-Priority: 3
-> Ralph,
Also
use
(only 2
then
I'm
-> Al
-> > Al,
David A. Ricker
Canada
David Ricker
wiring connectors
Thanks Wayne, good to know!
in
taxes
cost an
arm and a leg.
are
humungeous
LED lit
for
installatons
his
off a
Also
for
FINISH
general
note connector.
for
what
12:05:49 -0900
+0000
reply-
Also
use (only 2
then
I'm -----------------------------------------------------------------
David A. Ricker
Canada
David A. Ricker
Canada
wiring connectors
Post by Ken » Sat Feb 18, 2012 1:02 pm
www.alliedelec.com is similar and sometimes better prices.
US$6.50 for next day delivery to Canuckland includes shipping and brokerage.
Now if only ASS would set up a similar deal - eh?
in
taxes
cost an
arm and a leg.
snip
