All Mods
Ted Waltman
All Mods
Post by Ted Waltman » Sat Feb 18, 2012 12:58 pm
Brian (Godden),
If you're still on this email list, the below list of all (?) mods is
what I was suggesting you might use as a starting point for a
book/pamphlet/guide--what's been suggested by the factory and what
various owners have done. Pictures, pro/con, parts list (per mod),
unique tools (per mod), etc...
For what it's worth...
Ted
GARY MULREADY
Sent: Friday, January 07, 2005 1:55 PM
Subject: Re: Ontario Mods
I have tried to do a search for the "Ontario Mod" but come up with very
little. So I stated searching for mods and have listed what I have found
below. I agree that it would be of great help if all the mods that have
been done where in one location. This would help new builders like
myself gain from the knowledge of more experience builders.
-Irish Field Aviation Firewall Reinforcing Plates
-MAM "Float Fix" Channel
-Mckenzies STOL Mod
-Spring Gear Mod skin layering - Rebel
-Welded alum tank mod
-Aileron spade mod
-The Fus-30 doubler, at the tail post to tail spring bulkhead area.
-Tail Wheel Mod
-Bungee gear pivot mod
-Door mod
-Elevator Skin-rib reinforce outer edge
-Die Spring Gear
-Cabin Floor Stiffeners
-Fife Hoerner wing tips
-The only other things you'll need are 4 or 5 extra ST-28's, and one
extra FUS-30 - these are needed for "The Ontario Mods"
-There's an extra fitting that goes inside the float
bulkhead that MAY be included now (it was on the Elites)
-Float Fix Doubler slipped under Fus-9
-Corner Wraps
Gary
712R
wrayt@dcsol.com wrote:
If you go here http://wrayt.tripod.com/construction.html under other
stuff you'll see the upgraded corner wraps, the old fus 22 doubler,
Firewall stiffeners, flost fix stuff, gull wing doors etcs. Probably not
all the stuff but some of it anyway.
BRANSOM wrote:
With Bob's recent reference to the "Ontario Mods" I thought I'd go
back
through the archive and make a note of what they are. Searching for
Ontario
Mod in the Subject turns up zilch, and in Body turns up scattered
pieces.
Would anyone be so kind as to put up the generally accepted Ontario
Mods in
one place, such as in a reply under this subject?
Thanks very much,
Ben/ 496R
PS: my garage is too frickin cold and I'm in Ca (the other Ca)!
steve whitenect
All Mods
Post by steve whitenect » Sat Feb 18, 2012 12:58 pm
Guys
I have to apologize to the list. I ended up having some surgery before Xmas
and loads of company and didn't get around to listing in detail all the mods
I did to Rebel 637. Will try and do asap. Sorry about that
Steve W.
Subject: All Mods
Date: Fri, 7 Jan 2005 16:33:52 -0700
Brian (Godden),
Ted
GARY MULREADY
-Mckenzies STOL Mod
-Aileron spade mod
-Tail Wheel Mod
-Door mod
-Die Spring Gear
-Corner Wraps
Gary
712R
back
Ontario
pieces.
Mods in
Thanks very much,
Ben/ 496R
