Engines and props?
Brian J.
Engines and props?
Post by Brian J. » Sat Feb 18, 2012 12:26 pm
Here is the site. http://www.predatoraviation.com/ I've exchanged emails
with them and they should have a Moose kit in about 6 months.
Here is a link to the Robinson V8 Moose.
http://www.v8seabee.com/v8_powered_aircraft.asp
Brian
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Scott
Aldrich
Sent: Thursday, August 26, 2004 3:55 PM
Subject: RE: Engines and props?
Britt,
Was there a link to that article or was it only in the magazine?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Reed
Britt Civ OO-ALC/MADE
Sent: Thursday, August 26, 2004 12:51 PM
That article on the Corvette LS1 engine in the Vans RV7 had the 400 Hp
engine 10 lbs over the 180 Hp IO360 - The bummer is that he can't climb too
fast or there is no visibility over the cowl and he can't use all the
throttle till he is at 15,000 feet - Maybe you Canadians/Alaskans could use
the extra Hp too keep your beer cold till you are at altitude - in stead of
installing air conditioning -
Britt
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of WALTER
KLATT
Sent: Thursday, August 26, 2004 11:53 AM
Subject: Re: Engines and props?
Jerry, can you give us some performance figures, like rate of climb,
take-off times, etc. Also, what was your empty weight on wheels? And what
prop are you using?
If I was builing a Rebel again, I would seriously look at the 0360. While I
think my 150 hp 0320 does well on amphibs, it is certainly no water rocket.
There are definitely some places I would like to go into, that I don't dare
today.
Bruce G. and I met a guy up at Nimpo that put a turbo charger in his 0360
Bushmaster, which also sounded very interesting. I was certainly impressed
when he told me some of the places he had got into. I wonder how much weight
that would add to an installation.
Anybody want to buy a good used 0320? (just kidding)
List archives located at:
Engines and props?
Post by Bob Patterson » Sat Feb 18, 2012 12:26 pm
Hi Britt !
From numbers I've seen, that must have been one HEAVY
IO-360 !!! I would definitely talk to some folks who HAVE
one of the LS-1 or LS-6s - last I heard, the LS-6 was giving
the M-14P a good run in the weight department (slightly HEAVIER !).
-----------------------------------orig.---------------------
Britt
KLATT
prop are you using?
today.
Reed Britt Civ OO-ALC/MAD
Engines and props?
Post by Reed Britt Civ OO-ALC/MAD » Sat Feb 18, 2012 12:27 pm
Bob - I agree but I asked Chris about it and he was comparing a complete
system with Hartzel CS prop and a Ivo Prop so not really fair - But then
skip the turbo weight/cost and sacrifice in tbo (all those extra invoices
stuck behind in your seat pocket) that Walter referred to and it might be in
the neighborhood - I guess a copy of the Predator X8 weight and balance
would be convincing one way or the other -
Britt
Hi Britt !
Britt
WALTER
KLATT
prop are you using?
today.
weight
Jerry Purdom
Engines and props?
Post by Jerry Purdom » Sat Feb 18, 2012 12:27 pm
Sent: Friday, August 27, 2004 3:49 PM
Hi Drew
yes moved the firewall and did all the Wayne mods on firewall and corner
wraps etc.
THANKS
jerry
Sent: Thursday, August 26, 2004 2:02 PM
Thanks Jerry I thought I remembered someone had already done this. Did
you
move your firewall or strenghthen any parts?
At 09:59 AM 8/26/2004 -0700, you wrote:
Hi Drew I have been flying an 0-360 in my Rebel for 5 years on Edo 2000
it works fine.
Sent: Wednesday, August 25, 2004 6:53 PM
Subject: Engines and props?
bigger
for
too
much
As
prince
20hp
along
compression
an
Jerry Purdom
Engines and props?
Hi Drew
wraps etc.
THANKS
jerry
you
it works fine.
bigger
for
too
much
As
prince
20hp
along
compression
an
