Firewall brace
Firewall brace
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:58 am
Rick, by serial # you had at least two .025's FUS-70's and hopefully you
installed them on the lower carrythru to firewall sections! I had to buy two
more when I built mine, as I accidently installed the pair of .025's to the
top cabin to tailcone postion so had to order a new set for the intended
position. Turns out a good thing, since I have found on customers airplanes
that .020 in the upper tailcone to cabin position isn't the greatest!
Sent: Sunday, April 27, 2003 6:37 PM
Subject: Firewall brace
Thanks Bob & Phil ! .... can't remember if my corner wraps are .020" or
.025" ....I'll have to get out my verniers & go see ... (ouch, that'll
be a hell of a job if they're not !)
Rick & Wendy
541R
Firewall brace
Just forget about it Rick (and get a good night sleep!) and make sure that
you have the upper motor mounts reinforced as well as the door post
(staggered interpitched rivets or float fix bandaid at top of door post)
beefed up and fly the thing. It's no harder to replace those lower corner
wraps now or later, if they happen to deform during a hard landing. If they
never deform then you've saved youself a heck of a lot of work and the
attempt at matching the paint job!
Sent: Sunday, April 27, 2003 7:04 PM
Subject: Re: Firewall brace
Thanks Wayne !
Hell, I reckon I've got NO chance of figuring out if the other
corner wraps are .020" or .025" !?!
Assuming I DIDN'T stick the .025" ones on the lower firewall
carrythrough .... what effect / outcome will I be looking for /
expecting to see ?
Yours, now worryingly
Rick Harper
Sent: Monday, April 28, 2003 8:41 AM
you
buy two
to the
intended
airplanes
or
that'll
Rick & Wendy
541R
Archives located at
Rick Harper
Firewall brace
Post by Rick Harper » Sat Feb 18, 2012 1:58 am
Rick & Wendy
541R
Rick Harper
Firewall brace
Thanks Wayne !
expecting to see ?
Rick Harper
you
buy two
to the
intended
airplanes
or
that'll
Rick & Wendy
541R
Archives located at
Rick Harper
Firewall brace
Whew ! ... Thanks again (I don't know what us "Murphy Mob" would do
without great backup info like you !)
Thankfully, I've done the firewall bracing (triangle doubler plates) &
the double row staggered rivets on the door post .... in SS rivets too !
Thanks again Wayne ! :-)
Sent: Monday, April 28, 2003 9:05 AM
that
post)
corner
they
Thanks Wayne !
expecting to see ?
Rick Harper
hopefully
you
buy two
.025's
to the
intended
airplanes
greatest!
.020"
or
that'll
Rick & Wendy
541R
Archives located at
Archives located at
Archives located at
