[rebel-builders] Moose: Ray Allen Servo
Hans Kuck
Post by Hans Kuck » Sun Feb 19, 2012 8:29 pm
TED, could you please mail me a copy of the service bulletin regarding the
Ray Allen Servo. I was not aware that there was such a S.B. to
hansk3d@gmail.com
cheers
Hans
On Fri, Aug 21, 2009 at 7:58 PM, Ted Waltman <tedwaltman@gmail.com> wrote:
Fred,
AFAIK, every Moose owner uses this combination servo/actuator arm. Put the
sleeve on as per the service bulletin (get a sleeve at your local hardware
store if you don't have one already).
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Fred
Messinger (fredm)
Sent: Friday, August 21, 2009 3:45 PM
Subject: Re: [rebel-builders] Firewell caulk
Hi Guys,
I'm currently installing the elevator trim tab servo motor on my moose
quick
build.. The one MAM shipped is manufactured by The Ray Allen Company.
Everything (motor casing, clevis forks) is made out of a hard plastic
material. The push rod itself is a threaded metal rod, though.
My questions: Is anyone else using this set up? If not, which system are
you using?
I confess, I'm a little concerned about those flimsy little clevis forks
the plastic drive pin....especially in cold weather.
Fred
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
