Hello Jeffrey,
Haven't seen you on the list for a while. I made a new rudder pedal assembly and it will require 4 master cylinders toal. There are two in series for left and right. Tried to use the Matco with integral reservoir but the additional diameter and, more important, length made them unusable. I am looking for another set of the MAM standard units to which I can add screw in reservors. My fall back is the Matco which is same as or close to MAM dimensions.
All that said, do you have a set you will part with, and at what price? I will have the integral reservoir Matcos if you can use them for anything.
Regards,
Ralph
