Ivo Prop
Charles Dixon
Ivo Prop
Post by Charles Dixon » Fri Feb 17, 2012 8:56 pm
I have a Rebel with a 0-235.I have enclosed a message from IVO Prop
about their new 4.5" cord prop.It should be available in right hand turn
by Aug.It will be for the 100HP to 300HP range.I have been reading all
the e-mail,but have been waiting to put in my 3 cents.I did't build my
Rebel,it was completed and flying when I bought it.I had seen one at
Sun-N Fun and fell in love with it. At present job, just do not have
time to build one.After flying mine for about 10 hrs and reading all the
info on the internet,I decided it would need some beefing up before
flying it in Alaska.I got in touch with Wayne O'Shea and he agreed to do
what ever I wanted.After I pick it up I will let Ya'll know what all was
done.I have not had any trouble flying mine at low (50MPH) approach
speed.I do fly with power.I also bought a helicopter airspeed indicator,
much better at slow speeds.
Later,
Charles Dixon
The new meDium prop is 4.5 inch at its widest point with the Magnum
airfoil.
We have Left turn rear view Quick and Electric adjust now.
Right turn maybe in 6 months.
meDium Model Quick Adjust Propeller 52-74" diameter (4.5" cord)
Left turn rear view only.
2-blade $630.00 11.2 lb Right turn soon
3-blade $800.00 14.2 lb
meDium Model In Flight Adjust Prop System Left turn rear view only.
2-blade $1610.00 15.7 lb
3-blade $1780.00 19.2 lb
Retrofit kit $1100.00 6 lb
Regards, Ron/
ivoprop.com
