transponder requirement/ US
bransom
Post by bransom » Sun Feb 19, 2012 1:26 pm
Slight correction on this...
A transponder is required also to fly over (not just in) C or B space. I know
because I missed that on my private ticket check ride. Otherwise I didn't
break anything. :) Also, it makes sense -- if they see you on radar,
transponder is your only proof you are not IN their space, or sadly, that you
might be.
-Ben
-> Wayne,
-> A transponder is not required to fly over USA territory unless you
are
in "C" or "B" airspace such as any major airport l like SeaTac (Seattle)
or
Spokane International. most smaller general aviation towered airports,
like the
ones we use, allow flight without an encoding transponder.
-> Bruce G 357R
Unsubscrbe: rebel-builders-unsubscribe@dcsol.com
