Delivery Notification: Delivery has failed
Jerry Purdom
Post by Jerry Purdom » Sat Feb 18, 2012 12:27 pm
From: "Shaw Residential ISP Postmaster" <postmaster@shaw.ca>
To: <jerrygoneflying@shaw.ca>
Sent: Friday, August 27, 2004 4:05 PM
Subject: Delivery Notification: Delivery has failed
This report relates to a message you sent with the following header
fields:
Return-path: <jerrygoneflying@shaw.ca>
Received: from shaw_internet-daemon.l-daemon by l-daemon
(iPlanet Messaging Server 5.2 HotFix 1.18 (built Jul 28 2003))
id <0I3400B4ZO4J4R@l-daemon> (original mail from
jerrygoneflying@shaw.ca)
; Fri, 27 Aug 2004 17:05:45 -0600 (MDT)
Received: from pd4mr4so.prod.shaw.ca
(pd4mr4so-qfe3.prod.shaw.ca [10.0.141.215]) by l-daemon
with ESMTP id <0I3400FI5NPH6M@l-daemon> for mike.davis@dcsol.com; Fri,
27 Aug 2004 16:56:05 -0600 (MDT)
Received: from pn2ml5so.prod.shaw.ca ([10.0.121.149])
by pd4mr4so.prod.shaw.ca (Sun ONE Messaging Server 6.0 HotFix 1.01
(built Mar
15 2004)) with ESMTP id <0I340002DNPHPN40@pd4mr4so.prod.shaw.ca> for
mike.davis@dcsol.com; Fri, 27 Aug 2004 16:56:05 -0600 (MDT)
Received: from thehanger (S010600e07db6beb8.ok.shawcable.net
[24.71.85.52])
by l-daemon (iPlanet Messaging Server 5.2 HotFix 1.18 (built Jul 28
2003))
with SMTP id <0I3400B1RNPGSY@l-daemon> for mike.davis@dcsol.com; Fri,
Date: Fri, 27 Aug 2004 16:06:49 -0700
Subject: Fw: Engines and props?
To: mike.davis@dcsol.com
Message-id: <00c901c48c8a$88b11a60$34554718@ok.shawcable.net>
MIME-version: 1.0
X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
X-Mailer: Microsoft Outlook Express 6.00.2800.1106
Content-type: text/plain; charset=iso-8859-1
X-Priority: 3
X-MSMail-priority: Normal
Your message cannot be delivered to the following recipients:
Recipient address: mike.davis@dcsol.com
Reason: Remote SMTP server has rejected address
Diagnostic code: smtp;550 Return Path not verifiable.
Remote system: dns;mail.dcsol.com
(TCP|10.0.120.89|65509|209.193.47.105|25) (dcsol.com Wildcat! ESMTP Server
v6.0.451.1 ready)
