Jim, to clarify, I think that close tolerance bolts get you to the nominalMaybe someone has already mentioned this but along the line that AN bolts
are "a bit" undersized; along with reaming there are also the AN17 series
"close tolerance" bolts that are a few thousandths bigger in each size. I am
about to order a few 1/4 in. AN174 bolts from Aircraft Spruce.....
Jim
size, i.e. 1/4 is actually 1/4 not the usual undersized, but I don't think
they are over the .25 dimension.
I think this is correct,
Don B
