wing tip attach
wing tip attach
Post by Walter Klatt » Sat Feb 18, 2012 2:28 am
I'm sure most will tell you here to make them removable
with rivnuts or some kind of anchor nuts with screws.
However, in my case, by the time I got to attaching my
wing tips, I decided I had sufficient practice and
skills at drilling out rivets, so I just went the quick
and easy route, and riveted them on. So far no regrets.
Murray and Carol Cherkas
Sent: Sunday, August 17, 2003 8:41 PM
Subject: wing tip attach
Hello All
What is the best way to install wing tips?
Of course I have already drilled
all the holes as shown for riveting.I've
also got wingtip lights which may
require removing the tips at some point in
time.Should I use self tapping
screws? To rivet floating riv nuts would be
a big job,clip nuts may work for
one wing but the flange on the other is the
wrong way.
Advise me please.
Murray
http://www.dcsol.com:81/public/code/html-subs
cribe.wcx
Archives located at
wing tip attach
Post by Murray and Carol Cherkas » Sat Feb 18, 2012 2:28 am
Hello All
What is the best way to install wing tips? Of course I have already drilled
all the holes as shown for riveting.I've also got wingtip lights which may
require removing the tips at some point in time.Should I use self tapping
screws? To rivet floating riv nuts would be a big job,clip nuts may work for
one wing but the flange on the other is the wrong way.
Advise me please.
Murray
wing tip attach
Thanks W&W (Wayne,Walter-Walter,Wayne)Go figure
Thanks for confirming the alternatives. Will let you know after it happens.
Murray
Sent: Sunday, August 17, 2003 7:45 PM
Subject: Re: wing tip attach
Murray, clip nuts CAN be used on both wings. One wing you can clip over the
flange and rib from the outside and on the other wing you have to slide them
between the wing skin and the rib flange from inside the wing. You can also
use sheet metal screws. #8 in a #40 hole and big ugly #10's if you have
already drilled to #30 for rivets.
Sent: Sunday, August 17, 2003 11:41 PM
Hello All
drilled
for
Advise me please.
Murray
wing tip attach
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:28 am
Hello All
drilled
for
Advise me please.
Murray
