venting 101
Murray and Carol Cherkas
venting 101
Post by Murray and Carol Cherkas » Sat Feb 18, 2012 2:15 am
OK pretty basic but think about it.
Came out of the wing with a 1/4 pipe thread to #6 flair, 3/8 tube into
fuselodge to Tee fitting. Same on both sides. Now you have to connect the
two tee's. Instead of going straight across I felt that there should be a
little room for shrinkage and expansion so I drilled the centre channel on
the roof 1 1/2" forward of the root rib holes and as high as possible all
though very little height can be gained I kept the high point in the
middle.This allows two bends at each end of the centre tube which I think
will give and take a little bit, maybe not much but something is better than
nothing.
Good luck to all
Murray
Almost flying. Going to the paint shop next week.
