Terry
Murray Cherkas
Terry
Post by Murray Cherkas » Sat Feb 18, 2012 1:28 am
Just a reminder to add the reinforcing plate joining ST-31 to the fin spar.
Good luck
Murray
REBEL 505
Terry Dazey
Terry
Post by Terry Dazey » Sat Feb 18, 2012 1:28 am
Murray:
Yes, I accomplished that MAM plans change.
I ASSumed (I am not an engineer) that the cracking and rivet popping stemmed
from tailwheel ground side loading and not air loads.
Since my Rebel is going immediately to amphib floats, I ASSumed that the
FUS-30 Wayne doubler was not necessary. Am I correct on this Wayne?
Thanks for the "heads up" Murray . . .
Terry Dazey
Rebel 662
Sumner, Washington USA
wayne.o'shea
Terry
Post by wayne.o'shea » Sat Feb 18, 2012 1:28 am
WRONG ASSUMPTION!!!
The Fus-31 to tail post modification/doubler and the subsequent SB
issuance by MAM was my doing. It is not from tailwheel operations
what so ever and the cracking rivet shear is STRICTLY from air loads!!!!
The Fus-30 doubler is to handle tail wheel loads!
On 10/11/02 10:59 AM, DAZEY@EARTHLINK.NET wrote to MURPHY-REBEL:
-> on 10/5/02 8:23 PM, Murray Cherkas at cherkas@shaw.ca wrote:
-> > Just a reminder to add the reinforcing plate joining ST-31 to the fin
spar.
-> Murray:
-> Yes, I accomplished that MAM plans change.
-> I ASSumed (I am not an engineer) that the cracking and rivet popping stemmed
-> from tailwheel ground side loading and not air loads.
-> Since my Rebel is going immediately to amphib floats, I ASSumed that the
-> FUS-30 Wayne doubler was not necessary. Am I correct on this Wayne?
-> Thanks for the "heads up" Murray . . .
-> Terry Dazey
-> Rebel 662
-> Sumner, Washington USA
wayne.o'shea
Terry
Terry, wrong assumption if you are talking about the cracking of Fus-31
and the three post rivets shearing. I created this SB that MAM posted
2 years later and it is STRICTLY air loads that cause this FUS-31 to tail
post "failure".
-> Terry Dazey
-> Rebel 662
Terry Dazey
Terry
post "failure".
Hello Wayne: What I was trying to get at was that I had accomplished your FUS-31
horizontal bulkhead to post Service Bulletin, but I did not accomplish the FUS-30
double tail wrap because the airplane will not see any tailwheel time. It is going
straight to amphibs.
Understood, the FUS-31 is for airloads (past rivet popping and cracks) and the
FUS-30 is for "bullet proofing" for tailwheel side loads.
As usual . . THANKS for keeping things (me) straight!
Terry Dazey
Rebel 662
