pneumatic tailwheels
Shira Ellsworth
Post by Shira Ellsworth » Sat Feb 18, 2012 1:21 am
Hi everyone,
Has anyone switched to a pneumatic tailwheel?
If so which one did you go with?
Does anyone know what Murphy recommends?
I am looking at the options in Spruce.
The maule tailwheels are less expensive than the
Scott tailwheels, so I am wondering if the quality is
that much less with the maules, or am I ok going
with a Maule tailwheel? They are on page 217 in
the Spruce catalog, if anyone is interested in looking
at them.
Thanks for the advice,
Shira Ellsworth
Murpy Rebel 648R
sellsworth@cfl.rr.com
Sent: Tuesday, August 27, 2002 11:19 AM
Subject: RE: 120 degree versus 100 degree
100 degree worked fine for me as well. However, I flush riveted the
entire
aircraft so I likely used my tool more frequently than most. However, the
wing stringers I bucked with AN rivets and wherever it was easy access I
put
in AN rivets with a squeezer. I also did some testing of pull away
strength.
This is the force required to lift the skin off a surface along the axis
the rivet shaft. The AN rivets were slightly stronger and the failure
mode
was the skin would rip before the rivet failed. I was not able to test
them
in a shear mode (90 degrees to the axis of the rivet), my scale wouldn't
go
high enough for such testing.
Rick Muller
SR 070
On Mon, 26 Aug 2002 23:03:18 -0400 Keith Oliver <kboliver@adelphia.net>
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
[mailto:murphy-rebel@dcsol.com]On Behalf Of
S & L Aldrich
Sent: Monday, August 26, 2002 10:38 PM
I just used the 100 degree, they seemed to pull
in just fine. I thought this
had been discussed before but couldn't find
anything either. Anybody else
just use the 100?
Scott Aldrich
moose2b@dcsol.com
Sent: Monday, August 26, 2002 2:37 PM
Subject: 120 degree versus 100 degree
Hi everyone!
Searched the archives, but couldn't find the
answer. I've got 100 degree
countersinks and dimple tools. I've been told
the Avex CS rivets are 120
degree. Can I use the tools I've got, or do I
need new stuff? If I need 120
stuff, where can I buy it?
Terry Riedel
SR 171
To unsubscribe go to
http://www.dcsol.com:81/public/listserv.htm
Archives located at
mike.davis@dcsol.com
Archives located at
Archives located at
Post by Bob Patterson » Sat Feb 18, 2012 1:21 am
Hi Shira !
If your Rebel will be heavier ( using an O-320, or even an
O-235 ...), you will find going pneumatic will give a much better
ride and be easier on the airframe.
Go with the Scott 3200 (or a 2200, if you find one cheap !),
the Maules are cheaper for a reason !! I've flown both on different
aircraft - the Maule only has one side arm, and they tend to shimmy
badly when they get a bit worn.
The Scott 3200 is a popular choice with O-320's, because it
adds about 8 lb. right on the tail, which really helps the C of G !! :-)
Just my 2 cents .....
----------------------------------orig.--------------------------------
At 01:09 PM 8/27/02 -0400, you wrote:
Hi everyone,
at them.
Shira Ellsworth
Murpy Rebel 648R
entire
put
strength.
mode
them
go
Rick Muller
SR 070
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
S & L Aldrich
just use the 100?
Scott Aldrich
moose2b@dcsol.com
Hi everyone!
Terry Riedel
SR 171
Archives located at
Archives located at
Archives located at
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 1:21 am
Shira,
I know the price of the Maule tail wheel is tempting but I would never own a Maule tail wheel again. I am not alone in this recommendation as many pilots with more time and experience will attest to the same.
Maule tail wheels are a ground loop hazard waiting to happen. IMHO.
Bruce G 357R
Shira Ellsworth
Thanks Bob and Bruce for the advice,
looks like I'll go with the Scott 3200 since
I have an 0-320.
Shira
