SR Elevator Travel
Al & Deb Paxhia
SR Elevator Travel
Post by Al & Deb Paxhia » Sat Feb 18, 2012 1:04 am
I installed my stick today and it goes forward enough to strike the side panels where I have switches. Looks like the stops need to be adjusted. How many degrees of up and down elevator are required?
Al
SR#26
mike.davis
SR Elevator Travel
Post by mike.davis » Sat Feb 18, 2012 1:04 am
Apparently this is common, Chris Gills stick hits his master switch on the
left side... fortunately it turns it ON! The right stick hits the cabin heat
if it's on so he has added cabin heat off to his landing check list to ensure
he has full ailerons during landing.
On 3/30/2002 6:43 PM, MURPHY-REBEL@DCSOL.COM wrote to MIKE DAVIS:
-> I installed my stick today and it goes forward enough to strike the side =
-> panels where I have switches. Looks like the stops need to be adjusted. =
-> How many degrees of up and down elevator are required? =20
-> Al
-> SR#26
