Lycoming O-320 Conical Mount
Charles Skorupa
Post by Charles Skorupa » Sat Feb 18, 2012 12:47 am
Thanks Bob,
I agree with you on the Thorp cowl. I have nothing against the speed cowl,
but I sure like the wide open view of the engine compartment that my
Cherokee has and the T-18 looks like a good way to go. I didn't know you
could switch engine to a dynafocal. The 150 hp is my engine of choice for
all of th reasons you mention. We definately think alike in this area. The
O-320-A3A that I am looking at is a narrow deck engine. I think Lycoming
switched over to wide deck a little later. Anything I should be wary of
here?
Should I be looking for
Subject: Re: Lycoming O-320 Conicl Mount
Date: Fri, 15 Feb 2002 17:08:29 -0500
Hi Chuck !
Probably not a bad bet ! The conical mount engines can be
changed to Dynafocal fairly easily, if you want, but it should fit
right in. The O-320 mounts are the same as the O-235 mounts, so
that shouldn't be a problem either.
The speed cowl might be a problem - I understand there are
a couple of variants with different carb positions, and a couple
of different engine mounts to match up ...
If you're thinking floats, I would strongly recommend
using the "standard" cowl - it's MUCH easier to work on from floats.
You could use the Thorp T-18 nose bowl from Aircraft Spruce - it
is a bit sexier than the MAM Piper-style bowl. The advantage of the
aluminum cowl is that you can make it with double side hinges, so
you can have easy access to the whole engine by pulling two piano
hinge pins - it swings open top & bottom, and you aren't left holding
a large piece of fiberglass like the 'speed cowl' ....
The 150 hp. engines are first choice for floats, as they
are able to run regular car gas, which is about all you'll find
at most marinas. The 160 hp are higher compression, and need 100 LL....
Most of the Rebels up here run the 150 hp. O-320 for floats.
--------------------------------orig.-----------------------------------
At 05:04 PM 2/14/02 -0800, you wrote:
I have a chance to get a Lycoming O-320-A3A 150 hp engine. It is a
conical
mount configuration. Has anyone tried to use one of these or similar on
Rebel? I understand the speed cowling may not work. It also includes a
prop governor so I could go to a variable pitch prop. I am building an
Elite taildragger with eventual float configuration and can tolerate a
little more weight forward. Any cautions out there in Rebel-land?
- Chuck Skorupa -
Rebel Elite SN 500E
Get your FREE download of MSN Explorer at
http://explorer.msn.com/intl.asp.
Send and receive Hotmail on your mobile device: http://mobile.msn.com
Post by Bob Patterson » Sat Feb 18, 2012 12:47 am
I was surprised the first time I saw a "converted" Lycoming -
all they do is saw off the conical mounts and grind the case
down to provide a flat area for the Dynafocal rubbers to sit on !!!!!
The narrow decks weren't quite as strong - check carefully
for cracks in the case..... not a big problem. That's about all
I can think of to watch for. It is generally accepted that a set
of cylinders will not run past about 5,000 hours without major
cracks in the heads, around the plugs. This is between the second
and third 'run-out' timewise, so that's always something to watch
for. If you need new jugs, there are 3rd party products that are
more sturdy than Lycoming factory new..... Cracks in the heads
and corrosion in the cylinders, or on the camshaft, are the 'biggies'
to watch for on any engine.
I think there's a picture of Rick H's Rebel, in Australia,
with the Thorp nosebowl, in the archives somewhere. It was also
featured recently in Sport Aviation. If Wayne still has PFT up
there, he might be able to post a couple of shots of the cowling
on it - the best I've seen for access !
Hope your engine is relatively low time, and has no problems !!
-------------------------------------orig.----------------------------
At 06:32 PM 2/15/02 -0800, you wrote:
Thanks Bob,
here?
Hi Chuck !
conical
- Chuck Skorupa -
Rebel Elite SN 500E
Charles Skorupa
Bob (or anyone else),
Has anyone split the T-18 nosebowl. It is a pain to have to remove the prop
on my Piper Cherokee to get complete access.
- Chuck Skorupa -
Elite SN 500E (taildragger)
<<snip>>>
<<<Snip>>
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
I don't know of anyone - but, you do have a hacksaw,
don't you ??? ;-) ;-)
--------------------------------------orig.---------------------------
- Chuck Skorupa -
<<snip>>>
<<<Snip>>
LisaFly99
Post by LisaFly99 » Sat Feb 18, 2012 12:47 am
In a message dated 2/15/02 9:42:55 PM Central Standard Time, c_skorupa@hotmail.com writes:
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:47 am
What Bob's saying is definitely fact! The Rebel I shipped off to Maui had an
engine in it that was originally a conical O-235-C 108 H.P. engine. It had
been upgraded by Canadian Aero to a 118HP -LC2 with higher compression
pistons, etc, and had the conical "ears" cutoff and the case faced and
drilled for the dynafocal mounting (you didn't really think Lycoming paid
for new casting moulds did you!!??). I would just stick with the conical
mount the way it is. Rubbers are cheaper and the motor doesn't move around
as much. I know this extra movement is supposed to reduce the noise and
vibration in the airframe, but I haven't seen much difference and I've flown
them both numerous times.
As for Wide deck, narrow deck arguement, as long as you get a good engine to
start with I don't see it as an issue. I'm flying behind a narrow deck with
the "internal hex" nuts and cylinder plates. The oldest O-320's don't even
have the plates and for the amount of time we weekend warriors put on an
airplane in a year I don't think it's an issue!
As for cowls, if I have some time over the weekend I will see if I can take
some shots. I think my personal cowling is a step up from PFT's, but I have
both here so I will look them over and take some shots of both. FPT is still
in the marine container, awaiting repairs, so it might be tight to take the
shots but I'll see what I can do!
Regards,
Sent: Friday, February 15, 2002 10:21 PM
Subject: Re: Lycoming O-320 Conical Mount
Thanks Bob,
cowl,
for
The
here?
Hi Chuck !
At 05:04 PM 2/14/02 -0800, you wrote: conical
on
an
My light bulb just lit! I can't take pictures of FPT's cowling as I don't
have it! George removed the engine and cowling prior to me picking up his
airframe for repair.
Sent: Friday, February 15, 2002 11:38 PM
an
flown
with
take
have
still
Regards,
Thanks Bob,
cowl,
you
for
The
Lycoming
here?
LL....
similar
on
includes
an
itself
Wayne's right about the vibration damping - I've never noticed
any difference between the mounts when flying. The huge (1" or more !!)
movements of the engine on the Dynafocals might actually CAUSE
problems - there's a lot of extra flex on fuel lines, oil lines,
primer lines, wiring .... and even some possibility of damage
to the cowling ! I've seen scuffs from spinners touching, and
I worry about the side loads on the carburetor air box if it's
too tight a fit (needs rubber seals for flex).
Given that the conical Lord Mount rubbers are a lot
cheaper, you might just as well stay with the conical mounts.
....bobp
-------------------------------orig.--------------------------------------
Regards,
Thanks Bob,
cowl,
for
The
here?
on
an
