had a blower output as well as vacuum. (A lot of the newer vacuum don't
have a blower output they exhaust the air around the motor which is
mounted on top.) I mounted PVC fittings in the output port and then
installed quick disconnects like they sell for your garden hose into the
fitting. I got the idea of using the vacuum after looking and listening
to the commercial units at SNF.
I used a garden hose that was approved for drinking water (marked on the
package) for my supply line and put quick disconnect fittings on both
ends. What I found was the hose marked approved for drinking water
didn't have the "plastic" odor the other hoses had.
On the mask, I found a plumbing fitting that would fit the cartridge
opening. I then mounted a 90 degree elbow in this fitting to direct the
hose toward the floor. I cut about 4 foot of garden hose (enough to
reach the waist without binding) and put a quick disconnect on the waist
end. I attached the hose to the 90 degree fitting with a small hose
clamp.
I looked at the homebuilt article that was listed a couple of messages
back before I did my thing. What I found was that after I bought a
blower motor and then built a box, it was going to be about the same cost
and faster to use the wet \ dry vacuum. I used the quick disconnect
fittings in my hose so I could disassemble the rig and store things out
of the way. The fitting at the waist is so you can support the hose
without having the weight of the hose pull your mask off.
Good luck,
Terry
Sent: Thursday, February 07, 2002 11:04 PM
Subject: Re: Air System
atHi Gary
I have put up my DRAFT page on the blower photos, you can see itbecausehttp://www.dbis.ca/~ricker/Elite/HTML/Misc.htm. I call it draft
thefor publicsite is really in the setup stage and for now I consider it notinterestconsumption, I have provided you with the address because of your
inwhen I amthe fresh air blower. I will let the (mailing list) group know
readyattach theto go public.
Hope you find the photos useful.
Regards,
Dave R.
Gary wrote:
If possible some pictures would be of great help. Did you
lineaviationto a mask? I remember seeing something like that in one of the
magsremovedbut can't remember which mag it was. All I can remember is they
oneeffective, I cameof the filters in the mask an attach a line to it.
Gary M
Through Adversity To The Stars
712R
Sent: Sunday, February 03, 2002 5:01 PM
upout wellwith
butwant to$CDN30.00 andbreathe....bigbuilt a
ShopVacpipefilter
fittingsoverloadon the
thethis atblowerrun theabout acan pickblower
upall costsozone
forthehealth
shippingsee acratewith** To unsubscribe, send e-mail to list-server@dcsol.compicture, let
**itself** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by
**http://rebel:builder@www.dcsol.com:81/default.htm** Archives located at
****** To contact the list admin, e-mail mike.davis@dcsol.com
itself **
http://rebel:builder@www.dcsol.com:81/default.htm **
