Leaking Fuel Tank
Jim Stevens
Leaking Fuel Tank
I need advice on how to repair a leaking fuel tank. I did not build my Rebel
and the builder is no longer in the area but I do have the construction
manual. Any and all advice will be greatly appreciated.
Jim Stevens
C-IFXO
Surrey, B.C.
Jim Stevens
C-IFXO
Surrey, B.C.
Legeorgen
Leaking Fuel Tank
Jim,
Most builders cut 2 or 3 inspection holes in the offending tank. After it's
open you can stick your hand inside and clean up the area, then re-Proseal.
Try pressurizing the tank and brush with soapy water, if you don't already
know where the leak(s) is. Be careful if you have had gas in the tank already.
My tank, when pressure tested, leaked at the rear top seam and not the
rivets, so I cut my inspection holes in the bottom skin, in the bays aft of
the tank and sealed the seam(s) from the outside of the tank (inside the
wing). Clean everything up well with MEK before applying new Proseal.
The original builder tried to seal the leak in my tank with Randolph tank
sealant. This is an option although some builders don't like it (the leak
must be small for this to work). Some tank sealant will dissolve due to the
alcohol in gas. I have soaked a piece of aluminum with the tank sealant on it
in a jar of alcohol gas for over a year and see no affect. I pull it out
every few months and inspect it. Your call.
Bruce G 357R
Bruce G 357R
Charles Bailey
Leaking Fuel Tank
Jim,
I have S/N 176 and at that time the tanks used std. Avex Rivets, Not the
"Tank Rivets" that are now used in the fuel tanks. I had some rivets that
weeped from the mandrel hole. (look like weeping around the rivet on the
skin) I used thinned Randolph Sloshing Sealer # 912 (Alcohol resistant)
on a toothpick to fill the mandrel hole. It dries to an off white (yellow)
color. $18.95 from Aircraft Spruce. It may take several tries to fill each
hole. Pro Seal can be used if you have, dries dark. gray.
Chuck,
R176 N225PC
Sent: Saturday, January 26, 2002 10:07 PM
Subject: Leaking Fuel Tank
Chuck,
R176 N225PC
RebelI need advice on how to repair a leaking fuel tank. I did not build my
**and the builder is no longer in the area but I do have the construction
Jim Stevens
C-IFXO
Surrey, B.C.
**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself
**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
**** To contact the list admin, e-mail mike.davis@dcsol.com
Leaking Fuel Tank
Hi Jim !
It's an ultralight ! Do you have the 912, or a Lycoming ??
If you can tell us where it's leaking, there are several 'well-proven' (?)
methods to fix it. Don't use "sloshing" liquids, if you can
possibly avoid it - there have been numerous cases of the stuff
peeling off & clogging filters & lines !
It may be possible to seal it with ProSeal without even cutting
inspection covers, depending on where it's leaking. Is it just
a few rivets, or along the top rear seam, or at a stringer ??
Some of these can be sealed from outside the tank. There is a
thinner ProSeal that is suitable for brushing, that works well
for repairing small leaks. I think the number was mentioned recently
in the archives - last few months . You can search the archives
by keyword "ProSeal" or "tank" ...
If you're not sure of the location, you can try pressurizing
(gently - just 1 psi will do !) the tank, and brushing the seams
with soapy water & looking for bubbles.
Let us know, and we'll try to give a more detailed suggestion.
....bobp
---------------------------------orig.------------------------------
....bobp
Jim Stevens
C-IFXO
Surrey, B.C.
Jim Stevens
Leaking Fuel Tank
Hi Bob,
Thanks for your quick response. My Rebel is an ultralight with a 912
engine.
I don't know exactly where the leaks are but I can tell you this much, it
doesn't leak at the top of the tank, but it weeps in several places around
many of the rivets at the bottom of the tank and just last fall it really
began to leak badly at the wing root.
I was told by the previous owner that the weeping at the bottom of the tank
was caused by putting Mohawk fuel into the tank which damaged the ProSeal.
I am currently on a winter holiday in Arizona and will return to Surrey at
the end of March where the plane is and this tank project is my priority
this spring. I am not very far from Aircraft Spruce and Specialty so I can
easily acquire any materials by courier that I may need for this repair.
Any details you can provide on pressurizing the tank would be appreciated.
Jim Stevens
C-IFXO, Serial # 097
engine.
Jim Stevens
Jim Stevens
Leaking Fuel Tank
Hi Chuck,
Thanks for your prompt response. I have S/N 097 which use Avex rivets in
the tanks and much of the weeping is on the bottom of the tank however last
fall the tank began to leak bady near the wing root. This spring my priority
is to fix this tank.
Thanks again for your comments.
Jim
Sent: January 27, 2002 8:58 AM
Subject: Re: Leaking Fuel Tank
Jim
(yellow)Jim,
eachcolor. $18.95 from Aircraft Spruce. It may take several tries to fill
**hole. Pro Seal can be used if you have, dries dark. gray.
Chuck,
R176 N225PC
RebelI need advice on how to repair a leaking fuel tank. I did not build my**and the builder is no longer in the area but I do have the construction
Jim Stevens
C-IFXO
Surrey, B.C.
** To unsubscribe, send e-mail to list-server@dcsol.com with**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm**** To contact the list admin, e-mail mike.davis@dcsol.com
LisaFly99
Leaking Fuel Tank
In a message dated 1/28/02 8:17:31 AM Central Standard Time, jimthepilot@hotmail.com writes:
From all I've read MEK is supposed to be the only thing to effect Pro-Seal. Gas, aero or auto and their additives aren't supposed to bother the stuff. Was you're tank sloshed previously?
Phil&Lisa Smith
#460R
N414D
JIMI was told by the previous owner that the weeping at the bottom of the tank
Phil&Lisa Smith
#460R
N414D
Jim Stevens
Leaking Fuel Tank
Hi Bruce,
Since I'm not a builder could you please provide details on cutting and
sealing inspection holes in case I decide to go this route.
Also I'm not familiar with MEK and pressurizing the tank.
Jim
Sent: January 27, 2002 8:26 AM
Jim
it'sJim,
re-Proseal.open you can stick your hand inside and clean up the area, then
already.Try pressurizing the tank and brush with soapy water, if you don't already
ofMy tank, when pressure tested, leaked at the rear top seam and not the
thethe tank and sealed the seam(s) from the outside of the tank (inside the
italcohol in gas. I have soaked a piece of aluminum with the tank sealant on
**in a jar of alcohol gas for over a year and see no affect. I pull it out
Bruce G 357R
Flyin B Ranch
Leaking Fuel Tank
Another method I have seen done with success is to put a lite vacume on the filler cap and use ether sloshing compound or thinned proseal applied to the areas that leak. It will draw it in. But you must be very carefull as to much vacume could crush the tank.
Bruce in Oregon
Bruce in Oregon
Hi Bruce,
Jim
it'sJim,
Most builders cut 2 or 3 inspection holes in the offending tank. Afterre-Proseal.open you can stick your hand inside and clean up the area, thenalready.Try pressurizing the tank and brush with soapy water, if you don't already
know where the leak(s) is. Be careful if you have had gas in the tankofMy tank, when pressure tested, leaked at the rear top seam and not the
rivets, so I cut my inspection holes in the bottom skin, in the bays aftthethe tank and sealed the seam(s) from the outside of the tank (inside the
must be small for this to work). Some tank sealant will dissolve due toitalcohol in gas. I have soaked a piece of aluminum with the tank sealant onin a jar of alcohol gas for over a year and see no affect. I pull it out
Bruce G 357R
Legeorgen
Leaking Fuel Tank
Jim,
There are many different ways to cut inspection holes and use Pro Seal (you
can get Pro Seal from Aircraft Spruce, MEK at any hardware) and every builder
seems to have a different method.
I used a two headed fly wheel circle cutter to cut inspection holes (bought
at Harbor Freight) because you can use it free hand with a drill. Practice on
some scrap, aluminum to gain confidence, before attempting to use it on the
under wing skin.
If you cut the holes in the tank you will need to make doubler rings that
rivet to the tank skin and over lap the hole you cut out, leaving a 1/2"
flange to attach the cover plate you will have to make. Use tank rivets and
Pro Seal to seal everything. You will most likely have to make two or three
holes in each leaking tank.
If the holes are cut in the bay aft of the wing tank (like I did) you will
only need to make cover plates to over lap the hole and attach them with
Truss screws, anchor nuts and bolts or clip nuts.
To pressurize the tank and test for leaks, keep it simple. Rubber band a
latex glove over the tank filler cap. Put a rubber hose on the tank shut off
valve, plug all other openings and blow into the hose until the glove stands
up and shut the value to trap the air. If you have a leak the glove will
visibly deflate in a short time. Be sure to maintain a constant temperature.
If you come back the next day and the temperature is colder or warmer the
glove will deflate or expand accordingly. This is not a leak. bring the room
up to the same temperature and check the glove again. Barometric pressure
changes may effect this as well but I never experienced a noticeable
difference.
MEK is not good to touch or breath so protect your hands with gloves and use
a painters mask. Pro Seal comes in thick and thin. I have never used the thin
but many builders say it works well to patch holes because it can be brushed.
I use pop sickle sticks to apply the thick type. Good luck.
Bruce G 357R
under wing skin.
difference.
Bruce G 357R
Charles Skorupa
Leaking Fuel Tank
Check out:
http://communities.msn.com/NWRebelExper ... plate.msnw
for a template.
Chuck Skorupa
Elite SN 500E
Join the world
for a template.
Chuck Skorupa
Elite SN 500E
<<<snip>>>From: Legeorgen@cs.com
Date: Mon, 28 Jan 2002 11:03:05 EST
Jim,
builder
Join the world
LisaFly99
Leaking Fuel Tank
In a message dated 1/28/02 8:53:39 AM Central Standard Time, jimthepilot@hotmail.com writes:
Take Bruces warning about MEK (methel-ethel-keytone). The first MSDS (material safety data sheet) I read said it hasn't been clinically proven BUT is believed to cause irreversible nerve damage if breathed or absorbed. That was from DuPont Inc.
Phil&Lisa Smith
JIMAlso I'm not familiar with MEK
Phil&Lisa Smith
klehman
Leaking Fuel Tank
Jim
Probably a silly question, but did the previous owner build it and are
you certain you have pro-sealed tanks?
I think 097R would have originally shipped with molded plastic tanks
like 119R. The upgrade kit was of course available shortly thereafter
though.
though.
Jim Stevens wrote:
snip
Jim Stevens
Leaking Fuel Tank
Ken,
Thanks for your inquiry. This system of asking for help works well, I've
received some excellent ideas and information.
This kit wasn't registered until 1998 so it was built over a long period
of time. The builder did check with Murphy from time to time for upgrades
and incorporated them.
Now I'm not sure if the tank in trouble is coated with ProSeal because
one of the e mails I received said that ProSeal dries a dark grey color. The
material inside my tank is an off white color so probably it isn't ProSeal.
Jim
Sent: January 28, 2002 2:27 PM
Jim
tankJim
though.
Jim Stevens wrote:snip
ProSeal.was caused by putting Mohawk fuel into the tank which damaged the
**** To unsubscribe, send e-mail to list-server@dcsol.com with
Jim Stevens
Leaking Fuel Tank
Hi Phil & Lisa,
Yes my tank was coated on the inside with something that is an off white color, one of my e mails said that ProSeal should be a dark grey color. Unfortunately the builder moved from the area and I can't confirm the name of the material.
Jim
Jim
Sent: January 28, 2002 6:46 AM
In a message dated 1/28/02 8:17:31 AM Central Standard Time, jimthepilot@hotmail.com (jimthepilot@hotmail.com) writes:
Phil&Lisa Smith
#460R
N414D
