Aileron enhancement mod for lighter stick pressure is posted on MAM site. It
goes along with the new chapter 8 - Aileron assembly that was posted before
Christmas, with a new larger spade that is about twice as wide. Requires
taking out a rib and moving over the spade rib into it's place. Also
requires cutting off the rear spar extension of the wing, that sticks out
past all the other wing parts at the tip.
Sure glad the ailerons I have built are still open on the leading edge for
pre-close inspection by MDRA and I hadn't bothered building the spades!
Regards,
